- Button:
- Button.press(); – press Button
- Button.release(); – release Button
- Slider:
- Slider.cancel(); – cancel running fades
- Slider.down(TimeInSeconds); – fade to min Value
- Slider.fadeto(Value, TimeInSeconds); – fade to value
- Slider.get(); – get slider value as float.
- Slider.set(Value); – set slider value
- Slider.toggle(TimeInSeconds); – toggle fade between min and max
- Slider.up(TimeInSeconds); – fade to max Value
- Cuelist:
- Cuelist.get(); – get actual Cuenumber as Integer
- Cuelist.next(); – trigger next Cue
- Cuelist.previous(); – trigger previous Cue
- Cuelist.set(CueNumber); – set Cuenumber as Integer
- Cuelist.stop(); – trigger stop Cuelist
- Label:
- Label.get(); – get Label as String
- Label.set("String"); – set String
- Textfield:
- Textfield.append("String"); – append String to Textfield
- Textfield.appendLine("String"); – append String in new Line
- Textfield.clear(); – clear Textfield
- Textfield.get(); – get Text as String
- Textfield.getFloat(); – get Text as Float
- Textfield.getInt(); – get Text as Integer
- Textfield.set("String"); – set Text as String
- all Objects from the object tree has the following additional functions:
- xx.getChildren(); – returns a Array with objects
- xx.select(); – select object in inspector
- Area:
- Area.count(); – returns ammount of currently entered Objects as Integer
- Area.getEnteredObjects(); – returns currently entered Objects as object
- Area.isEmpty(); – returns a boolean, 1 if Area is empty 0 if is not
- Camera:
- Camera.activate(); – activate Camera in Viewport
- Action:
- Action.run(); – run action
- VarArray:
- VarArray.append(Variable); – append Variable to the Array
- VarArray.clear(); – remove all items from the Array
- VarArray.get(Index); – get Variable needs index
- VarArray.getArray(); – get the complete Array as array
- VarArray.remove(Index); – remove object with the given index from the Array
- VarArray.set(Variable, Index); – set Variable needs index
- VarArray.size(); – get the size of the Array, return Integer
- Script:
- Script.run(); – run trigger script
- Script.runValueChange(); – run ValueChange script
- Script.runWithDelay(); – run trigger script with delay
- Variable:
- Variable.get(); – get Var value
- Variable.set(Variable); – set Variable
*Variable type for VarArray and Variable can be Float, Integer, Bool, String, Color or Array.
