| Position | The position of the kinect along the XYZ axis can be set. |
| Scale | The scale in meters can be set here. |
| Rotation | The rotation on the XYZ axis can be set. |
Vbo Options
| Display Vbo | When on, the vertex buffer object will be displayed. |
| Draw Point Size | |
| Display Mesh | When on, the mesh will be displayed. |
| Capture | Pressing this button will add the Vbo to the objects panel and open its own parameter window. |
| Near Clipping | The near clipping range can be set here. This is the closest rendering distance. |
| Far Clipping | The far clipping range can be set here. This is the furthest rendering distance. |
| Clip Floor | When on, the floor will be rendered in the clipping distance. |
| Floor Height | The height of the floor can be set here in meters. |
| Clip With Object | When on, a set object can be added into the clipping frame. |
| Primitive Cube | The clipping object can be selected here. |
