MoSys are camera tracking and robotic tracking systems, this IO connection is an input and output for the tracking data.
MoSys Setup
Port This is the port that will receive data from other devices.
MoSys IP This is where the IP address of the server can be added.
Connected When the device is connected this will be on.
Interface This is the IP address of the local network interface which should be used for this connection.
MoSys Mapping
Position When on, the incoming position data will be used.
Rotation When on, the incoming rotational data will be used.
Lens Data When on, the incoming lens data will be used.
Transform
Position
  • Global Position – The object will be affected by the global position of the data.
  • Relative Position – The relative position will be output.
Rotation
  • Global Rotation – The object will be affected by the global rotational data.
  • Relative Rotation – The rotation of the object will be relative to the tracking data.
Status
Tracked State
  • Undefined – When tracker does not have a map input.
  • Inactive – When the tracker has a follow object input map.
  • Active – When the tracker has a target object map input.
Enable Recording When on, the input data can be recorded.
Compatible Input Objects
Maps Out
Transform
Position
  • Global Effected Position – The global effected position will be output.
  • Global Position – The global position will be output.
  • Target Position – The target position will be output.
Rotation
  • Global Effected Rotation – The global effected rotation will be output.
  • Global Rotation – The global rotation of the object will be output.
  • Relative Rotation – The relative rotation will be output.
Advanced sharing options
Trigger Send Pressing this button will send out a trigger value.
Use on Change When on, the trigger will be output in a time interval.
Use on Interval The time interval can be altered in milliseconds.
Timer Interval (ms) The time interval can be altered in milliseconds.
Compatible Output Objects
