Ranger with Center Setup
Lower | The lower or minimum range can be set here. |
Upper | The upper or maximum range can be set here. |
Center Point | The center point of the range values can be set. |
Center Threshold | The center point can be changed by percentage. |
Clamp Values | When on the values can not be changed. |
In | The input values will be displayed here. |
Normalised | The normalised value converts the output to values between 0 and 1. |
Out | The output values will be displayed here. |
Output Factor |
