The Infinite Board is similar to a Single Screen where it is used for a single flat screen. The difference between them is the pattern that is generated.
For a Single Screen, the pattern is generated using a constant marker size.
An Infinite Board generates concentric layers of markers with increasing marker size from the center outwards. It is possible to define the total number of layers to generate, and the number of row and column of markers to generate per layer.
Under the Screen section of the Inspector, you can define the number of layers, rows and columns of markers for the Infinite Board.
| Generate Texture | Trigger to generate a new texture based on the current setting |
| Dimension | The physical size of the entire screen |
| Rows | Number of rows of markers per layer |
| Columns | Number of columns of markers per layer |
| Layer | Number of concentric layers of different size of markers |
