Setting
Scale |
Rotation |
SP Pattern
Start Marker ID |
The ID of the first marker |
Marker Size |
The physical size of each marker |
Screen
Generate Texture |
Trigger to generate a new texture based on the current setting |
Screen Dimension |
The physical size of the entire screen |
Screen Resolution |
The video resolution of the entire screen |
To configure a calibration screen, there are a few key parameters that you need to configure:
- Depending on the situation, you might want to define the placement of the screen
- Define the physical dimension and resolution of the screen. It is extremely important that these values are absolutely accurate.
- Define the size of the marker and depending on the situation add and offset to the starting Marker ID.
