The topic you requested could not be found.
Wachendorff Encoder (WDGA36)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Wachendorff Encoder (WDGA36)
Setup Name Description Port Choose the Serial Port Input. Baut Rate The Baut Rate of the Serial Port. Name Description Encoder Type Singleturn Encoder Multiturn Encoder Value…
4 x Encoder Input (1047)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Phidgets » 4 x Encoder Input (1047)
Phidget Setup Name Description Device Serial The serial number of the device will be displayed when connected. Encoder 0 The value of encoder 0 will be displayed here. Autorange 0 When on, the ranges will be…
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Phidgets » Encoder Input Phidget (ENC 1000)
Name Description Device Serial When the device is connected the serial number will be displayed here. Hub Port The hub port can added into this section using the slider or manually inputting the number. Remote…
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with incoming DMX values
Prepare the Fixtures to full desk controll Select the fixtures which should be calibrated and set the Mix parameter all to the max value to have full controll from the lighting desk. *By using a map input for this, simply change this values from your lighting desk.…
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with self-generated values
Instead of using the lighting desk to focus on the measurement point during the calibration process, it´s also possible to position the fixture directly from SP. Make sure that SP has the full control Bring all Mix parameter to the minimum. Start Batch…
ncam
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » ncam
ncam Reality is a hybrid camera tracking solution. www.ncam-tech.com *This is only available for Virtual Production, and Full license. The ncam IO can be added with a click on the (+) within the IO Connections. Within the Inspector the ncam server IP and the…
DCS
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » DCS
DCS is a Lens Data Translator. www.dcs.film Stage Precision can receive data from the LDT-V1. *This is only available for Virtual Production, and Full license. The DCS IO can be added with a click on the (+) within the IO Connections. Within the Inspector the…
Spidercam (FRAME-B)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Spidercam (FRAME-B)
Spidercam is a cable camera system. Within Stage Precision it´s possible to read the position, rotation and lens data from a spidercam system. *This is only available for Virtual Production, and Full license. !Not each Spidercam product can send out tracking data.…
LOLED Virtual / LONET
Kinetic & Sensors
The Kinetic and Sensors section contains native automotive winches and equipment. The IO connections within this section are: MoveCat 4 x Encoder Input (1047) InterfaceKit 8/8/8 (1018) Voltage Input Phidget (V1000) Encoder Input Phidget (V1001) 8 x Voltage…
Phidgets
4 x Encoder Input InterfaceKit 8/8/8 Voltage Input Phidget Encoder Input Phidget 8 x Voltage Input Phidget 4 x Digital Input Phidget Spatial Phidget 4 x Digital Output Phidget
Supported Tracking Protocols
Stage Precision » Stage Precision » Workflows » Camera Calibration » Supported Tracking Protocols
Supported tracking protocols for different calibration methods: *These protocols can also be used in combination! Example: Protocol “A” supports “Lens Calibration” but not “Tracking Calibration”. Protocol “B” supports…
Cmotion
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Cmotion
*This is only available for Virtual Production, and Full license. Cmotion Setup Name Description Port Don’t Connect Standard Serial over Bluetooth Link (COM4) Standard Serial over Bluetooth Link (COM5) Baud Rate …
Lens & Tracking Calibration
1.1.46
Stage Precision » Changelog » 1.1.46
New Integrations: Indiemark Lens Encoder Indiemark 2 Lens Encoder Glassmark II Lens Encoder Websocket New Nodes: Fading MTC In New Features: New Camera calibration tool: Simple Static Calibration to calibrate a fix lens and align the camera with a single…
0.8.122
Stype (Stype HF)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Stype (Stype HF)
Stype is the combination of a RedSpy camera and follower which together can track objects and people within a space in XYZ directions. *This is only available for Virtual Production, and Full license. Stype Setup Input Name Description Local…
1.1.68
Stage Precision » Changelog » 1.1.68
New Sensor integration: Ouster 3D Lidar New IO Connection: Aumovis Grass Valley Native RossTalk Pixotope API integration Erizos API integration Qsys ECP Integration Spatial Phidget MOT 1102 New Objects: Text object New Node: Debounce New Camera…
Axis tools
Stage Precision » Stage Precision » Workflows » Camera Calibration » Axis tools
Axis is used to create a path of movement along an axis / track / spline based on encoder values and and image provider. If an object has multiple axes of movement, mutiple axes can be created one at a time and put one axis as a child of another to create a parent…
Camera Calibration
SP has several methods of Camera Calibration Tools depending on the need. Calibration Tools These tools can generate Lens Profiles and/or Alignment Profiles as well as position screens. Name Notes Generate Lens Profile Generate Alignment Profile…
Mo-Sys Axis Example
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » F4 (Mo-Sys) » Mo-Sys Axis Example
This is an example using the F4 (Mo-Sys) axis map inputs for a jib/crane that where there is a rotational pivot at the base a rotation encoder on the arm a remote pivot head mounted at the end of the arm. A camera is then mounted at the remote pivot head with a…
Tracking Alignment
F4 (Mo-Sys)
Mo-Sys are camera tracking and robotic tracking systems, this IO connection is an input and output for the tracking data. *This is only available for Virtual Production, and Full license. !Map/Node Outputs can be used not only to send the F4 protocol to different…
Parameter adjustment tool
Stage Precision » Stage Precision » Views / Elements » Inspector » Parameter adjustment tool
Each Parameter in Stage Precision has its own adjustment tool to modify the values. To open the adjustment tool, double click on a parameters name. When this window is open, you can use your arrow keys + special commands to modify the values: One single click…
Ranger with Center
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Ranger with Center
Ranger with Center Setup Name Description Lower The lower or minimum range can be set here. Upper The upper or maximum range can be set here. Center Point The center point of the range values can be set.…
Projection Size
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Projection Size
This node takes in positional values and calculated the angles between the XYZ values. Setup Name Description A A is the first vector input. B B is the second vector input. Angle X This is the calculated…
Joystick Ranger
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Joystick Ranger
Joystick Ranger Setup Name Description Lower X The lower or minimum X value range can be set. Upper X The upper or maximum X value range can be set. Center Point X The center point along the X range can be…
Vector Normalise
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Vector Normalise
The vector normaliser changes the input vector values to a value inbetween 0 and 1. Vector Normalise Setup Name Description Vector In This is the input vector values. Normalized These are the normalized output vector…
Distortion Viewer
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Camera » Distortion Viewer
The Distortion Viewer is a simple preview to visualize the distortion Values of the Camera object. There is one layer where a source can be distorted and another layer with an not distorted source. These layers can be combined to see if the distortion values matched…
Interpolator
Stage Precision » Stage Precision » Views / Elements » Objects » Combined » Interpolator
The Interpolator is a volume where reference points can be defined within it with reference values, and a target coordinate will compare its relationship with all the reference points coordinate and their values to interpolate a value for that location in…
Ranger
The ranger gives you the ability to set a range of input and output values. Ranger Setup Name Description Type Float – Individual X, Y or Z data. Vector – Combined XYZ data. Input Lower The minimum input…
In Range
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » In Range
This node compares three input values. When the value is in between the minimum and maximum values the result will be output. In Range Setup Name Description Type Float – Individual X, Y or Z data. Integer – These are…
Trigger
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Trigger
This is a trigger node, which takes in values from other nodes and can send out true or false output values. Trigger Setup Name Description Trigger When on, there is an input trigger value. Switch to True This is the…
Vector Cross
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Vector Cross
This calculates any cross or diagonal dimensions between vector values. Vector Cross Setup Name Description A This is the input area for the first vector value. B This is the input area for the second vector value.…
Vector Max
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Vector Max
Vector Max Setup Name Description Input This is a vector input, so contains XYZ values. Max This is the output of the largest input value, rounded to two decimal places. Min This is the smallest of the…
Light Tracking
Add/Setup Tracking Light Fixtures Define Measurement Points DMX Patch Calibration with incoming DMX values Calibration with self-generated values Live Control DMX Merge
Spline Ranger
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Spline Ranger
The spline ranger converts input values into output values between a range set within the node and at a rate determined by the type of spline. Setup Name Description Input Lower The lower value of the input range can be set here.…
Variable
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Links » Variable
The pool variable can be dragged onto the board and set up that way or this node can be used to target a specific pool variable. Setup Name Description Type Input – The nodes input values are determined by incoming values from…
OSC Event Maps
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » OSC » OSC Event Maps
Button input trigger A Button within the Board can be triggered with an OSC Map Input. The path needs to match the incoming data. This is an “on message” trigger. Everytime when some values will be received on this path the button will be triggered.…
Interpolate
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Interpolate
This is the combination or mixture between two values. Interpolate Setup Name Description Type Float – Individual X, Y or Z data. Point – This sends out XY data. Vector – Combined XYZ data. Colour – The…
Inspector
Variable parameter control Expressions parameter control Target selection Parameter adjustment tool Snap to Point The inspector is the section where all parameters are displayed and can be changed and altered. Parameters are separated into different groups and…
Cube
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Cube
A cube is a three-dimensional object made up of 6 faces, 12 edges and 8 vertices. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate…
Disc
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Disc
The disk is a two-dimensional shape that resembles a circle. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the…
Plane
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Plane
The plane is a flat two-dimensional shape. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the…
Sphere
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Sphere
The sphere is a three-dimensional geometric shape, with a resemblance to a ball. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate…
Timecode to Float
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Text Nodes » Timecode to Float
This node converts timecode into float output values. Setup Name Description Timecode This is the timecode input. Time This is the output float value. Layout Name Description Position…
KeyStroke
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » KeyStroke
This node generates integer values for each key on the keyboard. KeyStroke Setup Name Description Keystroke An integer value is generated and output each time a key is pressed. Layout Name Description …
Cone
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Cone
The cone is a three-dimensional shape with a flat circular face and curved sides that meet at a point called an apex or vertex. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. …
Cylinder
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Cylinder
The cylinder is a three-dimensional shape, that can be described as a circular prism with parallel sides and circular top and bottom. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local…
Moveable
Stage Precision » Stage Precision » Views / Elements » Objects » Kinetic » Moveable
The moveable consists of a set of start and end coordinates and/or start and end degrees, which can be used to control the movement of an object. Coordinates Name Description Position This will move the object along X, Y and Z axis in the…
Stage Precision » Stage Precision » Views / Elements » Inspector » Expressions parameter control
The control modes are different ways to control the various parameters of the objects. Manual Manual controls the XYZ parameters of the object by numerical values. These values are manually input or altered by the input map. Expression Expression control…
Global OSC Remote
Stage Precision » Stage Precision » General settings » Preferences » Global OSC Remote
All SP parameters have the ability to be controlled by OSC. The OSC receiver port can be set within the Preferences settings, this is the port that OSC values can be sent to with the specific address for the individual parameter. *The OSC Remote is separate from the…
OSC IO Event filter
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » OSC » OSC IO Event filter
The OSC IO can directly filter OSC messages to trigger actions in Stage Precision. Create an “on message” event directly in the IO to add a message filter with a click on the (+): It´s now possible to use different conditions: 1th…
DMX Merge
Stage Precision » Stage Precision » Workflows » Light Tracking » DMX Merge
Different signal flows can be supported. Merge within Stage Precision seperated networks By using multiple networks, it´s still possible to have the same patch for fixtures. SP is receiving the DMX network stream on one deticated network interface and send out on…
DMX Merge
Light Fixture
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Light Fixture
This is an interchangeable moving light fixture. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the…
Surface
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Surface
This is a plane or surface that is constructed from the placement of four points. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate…
Mesh
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Mesh
The mesh object allows an external 3D model to be imported into the scene. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To…
Spy
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Spy
Spy Setup Name Description Type String Float Point Vector Interger Colour Bool Decimal Points This is the number of numbers that follow after the decimal point. Inputs There are multiple inputs…
Switch
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Switch
This switch node is able to take in multiple values, as well as a switch value which controls which of the input values are outputted. Setup Name Description Type Float – Individual X, Y or Z data. Integer – These are…
Winch 3
Stage Precision » Stage Precision » Views / Elements » Objects » Kinetic » Winch 3
The winch 3 object has three chain and hook points arranged in a triangle. These can be attached to one object and allow for rotation as well as linear movements. *This is only available for Kinetic Control, Full, and Engineer license. *The tree…
Vector -> Float
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Convert Nodes » Vector -> Float
This takes one vector input which contains XYZ data and separates this data into separate values. Vector2Float Setup Name Description Vector This is the input area for the vector XYZ data package. X This is X axis float…
Sony FR7
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Sony FR7
Prepare the camera First the freeD feedback output needs to be activated Make sure, that this values are matching with the SP settings: - Camera ID - Destination IP - Destination Port Enable Visca for the FR7 Enable Tally over Visca Range the Zoom and…
Multipixel
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Multipixel
This is a multipixel object the number of pixels can be altered. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the…
Spline
Stage Precision » Stage Precision » Views / Elements » Objects » Objects » Spline
A spline is a curve in 3D space, which is defined by two or more points. They can be used in multiple ways such as; animation tracks and object alignment. Splines can be imported as Fbx files. Coordinates Name Description Position This…
Measurement Line
Stage Precision » Stage Precision » Views / Elements » Objects » Utilities » Measurement Line
The Measurement Line is a tool to measure within the viewport between two points. The Inspector shows the measured distance result and the angle between booth points. Each point can be set with the following different methods: Manual values To use manual…
Monitor
Stage Precision » Stage Precision » Views / Elements » Monitor
The monitor can be used to display changes in individual parameters over a period of time. Monitor Setup Name Description Parameter The parameter can be selected using the target button. Type Continious Time…
Float to Timecode
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Text Nodes » Float to Timecode
This node converts incoming float values into a timecode output. Setup Name Description Time This is the float input for the time value. Timecode This is the generated timecode output. Hours This is the…
Colour -> CMYK
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Colour Nodes » Colour -> CMYK
This converts combined colour data into separate CMYK (Cyan, Magenta, Yellow, Black) float values. Colur2CMYK Setup Name Description Colour This displays the input colour. C This is the output value of the cyan…
Trigger Delayed
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Trigger Delayed
This is a trigger node with a delay value. The node takes in values from other nodes and outputs triggers whether the event is true or false. Trigger Delayed Setup Name Description Trigger When on, there is an input trigger value.…
Formula
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Formula
This calculation node allows for any sum to be created between three variables. Formula Setup Name Description Formula The sum or formula can be completely changed and varied. (Add, Subtract, Multiply and Divide.) Variables…
OnChange
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » OnChange
This node generates a trigger event when any of the pins have changed its value. OnChange Setup Press the “+” button to create extra pins. For each of the pins, there are the following options: Name Description Type …
Colour Field
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Colour Field
This is a colour block with input and output mapping. Colour Field Setup Name Description Colour Clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. Layout Name Description…
Pixel
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Pixel
This is a single RGB pixel. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the settings under…
Winch 2
Stage Precision » Stage Precision » Views / Elements » Objects » Kinetic » Winch 2
*This is only available for Kinetic Control, Full, and Engineer license. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To…
Euler to Quaternion
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Convert Nodes » Euler to Quaternion
This converts Euler values into Quaternion. Euler to Quaternion
Quaternionto Euler
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Convert Nodes » Quaternionto Euler
This converts Quaternion values into Euler. Quaternion to Euler
Wave Generator
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Generator Nodes » Wave Generator
This is a node-based wave generator which can affect movement or other parameters of objects. Wave Generator Setup Name Description Type Sine – This is a simple waveform. Cos – This is a simple waveform similar to sine,…
PTZ
All of the manufacturer specific PTZ camera objects would be organized under this category. Currently, we have the following manufacturer specific PTZ cameras: Panasonic UE 100 Panasonic UE 150 Panasonic UE 160 Sony BRC-X1000 Sony FR7 !The Sony camera…
Recording only Object
Stage Precision » Stage Precision » Views / Elements » Timeline Recording » Enable Objects / Interfaces for Recording » Recording only Object
Since only the changing parameters will be recorded, it´s necessary to create a “recording object” to bring all needed parameters into one object. Example: The to recorded object is the Camera object called “LensData”. Within the tree…
Tracker
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Tracker
The tracker can take the form of rigid bodies or points. These objects can be controlled by or output positional data as well as acting as measuring points or triggers. Coordinates Name Description Position This will move the object along…
PTZ Camera Control
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Skeleton
This is a virtual representation of the human body, with 24 joints that correspond to points on the body. Each of the joints have 11 different properties; colour, depth, camera and orientation in the X, Y and Z axis. Coordinates Name Description…
Spotlight
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Spotlight
This is a set light fixture that is usually used to light an object or person. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system.…
Stage Precision » Stage Precision » Scripting » General use of Scripting » Work with different parameter types
Float value.get() will return the value. value.set(123) will set the value to 123,00. value.set(456.789) will set the value to 456,789. Int value.get() will return the value. value.set(123) will set the value to…
Graph
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Graph
A graph is an interface object to analyse/draw float values/data. Add a Graph Input node for the Graph *If the node will be an output, simply change the type to an input within the inspector. Time Based Graph This Graph is drawing whenever the input…
XYPanel
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » XYPanel
An XY position can be altered and output from this panel. XY Panel Setup Name Description Value These are the numerical values of the XY position of the dot. Layout Name Description Colour The…
Compare
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Compare
This node compares two input values and outputs the result if the value is true. Compare Setup Name Description Type Float – Individual X, Y or Z data. Integer – These are whole numbers. Function ==…
Dropdown
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Dropdown
A Dropdown can be created within any Board. With this interface it´s possible to create an own dropdown menu with custom names and custom parameter for each dropdown entrie. Dropdown Entries A click on the (+) create a new entrie. Each entrie can have…
Rigid Body
Stage Precision » Stage Precision » Views / Elements » Objects » Combined » Rigid Body
This is a 3D body that moves under physics and collides with other objects. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system.…
Compare Period
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Compare Period
This node compares two input values and outputs the result if the value is true, this output lasts for a period of time which can be set. Compare Period Setup Name Description Type Float – Individual X, Y or Z data. Integer…
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Tracking Light Fixture
The Tracking Light Fixture is an object to follow a Target and drive a real moving head fixture in real time. It can send and receive DMX data over ArtNet and/or sACN. *This is only available for Light Tracking, Full, and Engineer license. This object can not only…
Centroid
Stage Precision » Stage Precision » Views / Elements » Objects » Combined » Centroid
The centroid is the average center of a selected number of points, as the tracked points move the centroid will automatically update. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. …
Plain Effector
Stage Precision » Stage Precision » Views / Elements » Objects » Effector » Plain Effector
This is a linear effector, where the changed parameters only work within or around the effector itself. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale…
Gradient Effector
Stage Precision » Stage Precision » Views / Elements » Objects » Effector » Gradient Effector
Sound Card
Stage Precision » Stage Precision » Views / Elements » IO Connections » Audio » Sound Card
The settings of the sound card in the server can be altered and changed within this section. Sound Card Setup Name Description Input Gain The amount of input gain can be altered here. Activity Threshold The activity…
Fixture Profile
Stage Precision » Stage Precision » Views / Elements » Pool » Fixture Profile
A Fixture Profile is necessary to use a Tracking Light Fixture. The Fixture Profile contains the DMX patch and physical parameter to receive/drive a light fixture. Device It´s possible to define here some informations about the fixture. !The “Total…
Area
Stage Precision » Stage Precision » Views / Elements » Objects » Logic » Area
This is an area within the virtual 3D space and has the ability to detect virtual objects entering and leaving the space. This can be used to output a variety of messages and triggers internally and externally from Stage Precision. Coordinates Name…
Volume
Stage Precision » Stage Precision » Views / Elements » Objects » Combined » Volume
The volume is able to take in multiple point data such as point clouds. Points from within that data can be singled out and data outputted. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local…
