This is a linear effector, where the changed parameters only work within or around the effector itself.
| Weight | This is the amount that the objects are affected, the higher the number the more the objects are affected. |
| Position | Position along the X, Y and Z axis, that the objects will move when interacting with the effector. |
| Rotation | Rotation along the X, Y and Z axis, that the objects will do when interacting with the effector. |
| Colour | Clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. |
Falloff
| Position Type |
| Falloff | When increased this will create a feathered effect to the affected area, if at 0 the falloff point will be a line. |
| Radius | Distance from the center of the object to the edge of the circle in meters. |
| Cube Size | Dimensions of the cubes width, height and length. |
| Invert | When ticked, the effector will only affect objects within its shape. When un-ticked, it will invert the effect and only affect those outside the shape. |
Effected Objects
Parameter
| Target | A target object can be selected by using the trigger button. The target object/s will be affected by the effector. |
| Filter |
Video Tutorial
Plain Effector setup begins at 00:45.
The plain effector can be manipulated in the board by adding the effector as a node, this can be done by clicking and dragging the specific effector on the board.
| Target Object | This is the object that will either be affected by the incoming values or output information. |
| Position | The directional XYZ values will be displayed here. |
| Rotation | The rotational XYZ values will be displayed here. |
| Enabled | When on, the parameter is active and enabled. |
| Displayed Colour | This colour block can be changed by changing the parameter display colour. |
