The topic you requested could not be found.
1.1.90-92
Stage Precision » Changelog » 1.1.90-92
New Objects: Orbbec Femto Mega StreamDeck New IO Connection: Phiget Rel1100 ADM-OSC Kinesys New Features: All tracking map inputs have now delays for position, rotation and all additional custom data like zoom, focus etc. New Camera calibration…
Optitrack Camera Setup
3D Tracking
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking
This 3D tracking section contains IO connections for 3D objects and 3D space tracking, including objects, skeletons and cameras. All of these tracking protocols have XYZ data. The IO connections within this section are: Antilatency Blacktrax…
Object Grid
Stage Precision » Stage Precision » Views / Elements » Object Grid
This is a view where objects are displayed in a grid like format. This is particularly useful when looking at multiple Optitrack Cameras. To add an optitrack camera into the Object Grid window, right click on an optitrack camera sensor, and there is an option for…
Optitrack Volume Add Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Volume Add Camera
There are 2 ways that Optitrack Camera can be added as part of the Optitrack Volume. Adding a Camera Manually From the Object tree, you can add an Optitrack Camera object manually and entering the serial number of the device manually. For details, please refer to…
Blob Tracking Workflows
Stage Precision » Stage Precision » Workflows » Blob Tracking Workflows
Within SP, there are 2 different types of blob tracking possible depending on the type of sensor Image Based Blob Tracking analyzes data from an image to detect a blob or an object of interest. This could be done with an standard color image or a black and white…
0.8.134 / 0.8.135
1.1.0
Optitrack (NatNet)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Optitrack (NatNet)
This is a native input for Optitrack NatNet data. *This is only available for Virtual Production, Tracking, Light Tracking, and Full license. Optitracks (NatNet) Setup Input Name Description Server IP This is the port that the data…
Supported Tracking Protocols
Stage Precision » Stage Precision » Workflows » Camera Calibration » Supported Tracking Protocols
Supported tracking protocols for different calibration methods: *These protocols can also be used in combination! Example: Protocol “A” supports “Lens Calibration” but not “Tracking Calibration”. Protocol “B” supports…
