Search
Visca over IP
Stage Precision » Stage Precision » Views / Elements » IO Connections » PTZ Cameras » Visca over IP
Visca over IP is a control protocol to drive PTZ cameras. There are two options within Stage Precision to use Visca over IP: Send commands / call presets / send custom messages Drive the complete PTZ camera Visca IO Connection Camera Number is by default…
Visca Server
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » Visca Server
The Visca Server IO creates an Visca over IP endpoint, so that SP can be controlled from a Visca based PTZ controller. *This is only available for Virtual Production, Light Tracking, Engineer, and Full license. Setup the Visca Server Connection Add the Visca Server…
PTZ Camera Control
1.1.128
Stage Precision » Changelog » 1.1.128
New Sensors / IO Connections: Robosense 3D lidar Canon CV Protocol New Maps: Visca Map Joystick input for PTZ Cameras Visca Map input for Target Frame New Features: New Volume Filter – Scale New Volume Filter – Offset Add calibration tools for…
Sony FR7
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Sony FR7
Prepare the camera First the freeD feedback output needs to be activated Make sure, that this values are matching with the SP settings: - Camera ID - Destination IP - Destination Port Enable Visca for the FR7 Enable Tally over Visca Range the Zoom and…
0.8.134 / 0.8.135
0.8.130
Stage Precision » Changelog » 0.8.130
new IO Connections: FactoryOptics Spidercam Visca Watchout Trackman Telnet Phidget 0/16/16 New Nodes: Vector Axis Swapper Threshold Wait for trigger Script nodes can be now pushed/run with a trigger. Ping interface Trigger Count Trigger Switch New…
0.8.131
Stage Precision » Changelog » 0.8.131
New IO Connections: Object Transform Protocol Update Azure Kinect to SDK Version 1.4.1 (Firmware 1.6.110079014) Update Visca New Nodes: Composition Nodes / Nested Nodes Current Date Date to string Date Converter New Interface Object: Button Group New…
Tracking Light Fixture
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Tracking Light Fixture
The Tracking Light Fixture is an object to follow a Target and drive a real moving head fixture in real time. It can send and receive DMX data over ArtNet and/or sACN. *This is only available for Light Tracking, Full, and Engineer license. This object can not only…
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Technocrane Serial (SUPERTECHNO)
The Technocrane is a camera crane system, this is the input for the crane tracking system. *This is only available for Virtual Production, and Full license. Technocrane Serial Setup Name Description Port Don’t Connect Standard…
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Camera
Web Camera Name Description Camera Link A camera object can be linked to this camera node. Camera The camera input can be selected using the drop-down list. Overlay Enabling this overlays the target parameter…
Orbbec Femto Mega
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Orbbec Femto Mega
The Femto Mega from Orbbec is a multi-mode Depth and RGB camera with real-time streaming over Ethernet or USB connections. This sensor object is supporting the image based blob tracking as well as the point cloud blob tracking workflows. Power Up the Sensor Please…
Optitrack Analysis
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Analysis
Analyse Recording This tool is used to record some tracking data and this tracking data can be used at a later time to analyse the accuracy of the tracking system. It is useful to help analyse whether some cameras have shifted over time since the last calbration, and…
Curve Motion
Stage Precision » Stage Precision » Motions » Curve Motion
*The curve parameter can be copy and pasted over to another parameter. To do so, right click on the curve and there is the option for Copy Curve and Paste Curve
Shield for Unreal
Shield for Unreal
Shield is our virtual production-optimized plugin for Unreal Engine 4. It interacts perfectly with Stage Precision and the combination of both. Shield gives you full control over your virtual scenes. With shield, you can easily process camera tracking inputs and split…
Camera Analysis
Stage Precision » Stage Precision » Views / Elements » Objects » Utilities » Camera Analysis
The Camera Analysis object is a volume in the 3D space that can be used to analyze the coverage of multiple cameras. On top of the basic parameters like the position, scale and rotation, the Camera Analysis object has some unit parameters. Camera Analysis Setup …
Monitor
Stage Precision » Stage Precision » Views / Elements » Monitor
The monitor can be used to display changes in individual parameters over a period of time. Monitor Setup Name Description Parameter The parameter can be selected using the target button. Type Continious Time…
Cmotion
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Cmotion
*This is only available for Virtual Production, and Full license. Cmotion Setup Name Description Port Don’t Connect Standard Serial over Bluetooth Link (COM4) Standard Serial over Bluetooth Link (COM5) Baud Rate …
Q-Sys ECP
Stage Precision » Stage Precision » Views / Elements » IO Connections » External Platform » Q-Sys ECP
Q-sys ECP or Q-Sys External Control Protocol is used to communicate with the Q-Sys Designer Software and firmware. Q-sys ECP Name Description Remote Host This is where the target IP address of the host can be input. Remote…
Timeline
Stage Precision » Stage Precision » Views / Elements » Timeline
The timeline allows for adding layers, keyframing and triggering events over a period of time. The timeline is made up of the time-based timeline, blocks and keyframes. The individual keyframes and layers are stored within blocks and these blocks can be manually…
StreamDeck
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » StreamDeck
StreamDeck is a controller accessory for a PC. There are 2 different ways that a StreamDeck can be connected to SP. Direct Connection If the StreamDeck is directly connected to the SP machine via local USB, there is a StreamDeck object under the object tree inside…
Websocket
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » Websocket
WebSocket is a computer communications protocol, providing simultaneous two-way communication channels over a single Transmission Control Protocol (TCP) connection. Setup Name Description Server IP The URL to connect to a websocket…
Preferences
Gateway » Preferences
Gateway is running as background process. You can configurate and find Gateway after the installation in your Taskbar. To change the settings or quit Gateway you can click on the Gateway icon to open the menu. Within the Preferences define “Name”…
Modulo
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Calculate Nodes » Modulo
The modulo calculates the remainder after the input value is divided by the modulo value, the value that is left over will be output as the result. Modulo Setup Name Description Value This is an input float value. Modulo…
TCP
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » TCP
TCP is an error checking protocol, it is slower than UDP but will receive confirmation that the data package has been received. TCP Setup Protocol Name Description Protocol Type Raw – This is data that has not been…
StreamDeck Plugin
StreamDeck Plugin
A StreamDeck can be used on the same computer where Stage Precision is running and also over network from other computers. Install the Stage Precision Stream Deck plugin by double click on the plugin file. After the installation is done open the StreamDeck…
ADM-OSC
Stage Precision » Stage Precision » Views / Elements » IO Connections » Audio » ADM-OSC
ADM OSC is an industry initiative for standardization of Object-Based Audio (OBA) positioning data in live production ecosystems by implementing the Audio Definition Model (ADM) over Open Sound Control (OSC). Setup Name Description Send Mode…
Releasing License
Stage Precision » Licenses » Releasing License
Releasing a license from a machine frees the license so that it could be added to another machine. How to Release a License from an Online Machine Open the License Manager of SP via the Help menu. From the License Manager window, you would be able to see all of…
Inspector
Stage Precision » Stage Precision » Views / Elements » Inspector
Variable parameter control Expressions parameter control Target selection Parameter adjustment tool Snap to Point The inspector is the section where all parameters are displayed and can be changed and altered. Parameters are separated into different groups and…
Math functions
Stage Precision » Stage Precision » Scripting » General use of Scripting » Math functions
Math.abs(); Math.abs(value); The Math.abs() function returns the absolute value of a number. That is, it returns x if x is positive or zero, and the negation of x if x is negative. Math.random(); Math.random(); The Math.random() function returns a…
UDP
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » UDP
User datagram protocol is a low-latency protocol, smaller data packets are sent and no response message is relayed back to the sender. This protocol is node-based, this worked with input and output messages within the board. UDP Setup Protocol Name…
Lens & Tracking Calibration
Adding License
Stage Precision » Licenses » Adding License
How to Obtain the License Key Once a license has been purchased successfully from our webstore an email should be sent to the registered email of the account with the license key attached in the email. Alternatively from the webstore, you are able to look at the…
Optitrack (NatNet)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Optitrack (NatNet)
This is a native input for Optitrack NatNet data. *This is only available for Virtual Production, Tracking, Light Tracking, and Full license. Optitracks (NatNet) Setup Input Name Description Server IP This is the port that the data…
Hive
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Hive
Hive is a media playback system which can be controlled remotly from SP. hive.run Setup the connection Within the IO-Connection add a Hive IO. Define the IP of the Hive player and choose your local interface Trigger Maps Trigger maps can be “called”…
Panasonic AV-HS450
Stage Precision » Stage Precision » Views / Elements » IO Connections » Switcher » Panasonic AV-HS450
Panasonic AV-HS450 Setup Name Description Protocol Raw – This is data that has not been processed. Lines – This sends data over a transmission line that will not overlap. Data255 - COBS – (Consistent Overhead Byte…
Board & Nodes
Interface Camera Links Objects Nodes Calculate Nodes Math Nodes Convert Nodes Smoothing Nodes Colour Nodes Utility Nodes Text Nodes Event Nodes Generator Nodes Composition Nodes Board Object Selection Layout The board acts as a control panel. Within…
Objects
The objects section is where all fixtures, objects and structures are stored and arranged. When SP initially starts up the objects view will be in the top left-hand corner. The objects section includes all of the scene building models, fixtures and shapes. To add…
Formula Effector
Stage Precision » Stage Precision » Views / Elements » Objects » Effector » Formula Effector
This effector uses the formula of wave formations to affect the target objects. With full control over how the formula is written, the time, count and index can be changed which alters how the wave affects the objects. Coordinates Name Description…
0.8.122
Pixera
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Pixera
PIXERA is a 64-bit media server system for real-time media processing and compositing and management, which is built around the theme of usability. Pixera Setup Name Description Update Handle Ids When pressing the button the handle Ids…
Shield actor
Shield for Unreal » Setting & Functions (v0.8) » Shield actor
The Shield actor is a CineCamera based actor. This actor takes care about the different render passes, includes lens distortion, processed shadow / reflection catcher and can be driven over Live Link. !Supported is one single Shield actor per level. !All…
Stage Precision » Stage Precision » Maps / Filter / Trigger » Filters
Input Filters Tracking Name Description Window Size This is the size of the tracking area. Reset Position threshold The position threshold can be altered here. Reset Interpolation Time The interpolation…
