Search
3D Tracking
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking
This 3D tracking section contains IO connections for 3D objects and 3D space tracking, including objects, skeletons and cameras. All of these tracking protocols have XYZ data. The IO connections within this section are: Antilatency Blacktrax…
Optitrack Camera Setup
Object Grid
Stage Precision » Stage Precision » Views / Elements » Object Grid
This is a view where objects are displayed in a grid like format. This is particularly useful when looking at multiple Optitrack Cameras. To add an optitrack camera into the Object Grid window, right click on an optitrack camera sensor, and there is an option for…
Optitrack Volume Add Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Volume Add Camera
There are 2 ways that Optitrack Camera can be added as part of the Optitrack Volume. Adding a Camera Manually From the Object tree, you can add an Optitrack Camera object manually and entering the serial number of the device manually. For details, please refer to…
1.1.90-92
Stage Precision » Changelog » 1.1.90-92
New Objects: Orbbec Femto Mega StreamDeck New IO Connection: Phiget Rel1100 ADM-OSC Kinesys New Features: All tracking map inputs have now delays for position, rotation and all additional custom data like zoom, focus etc. New Camera calibration…
Blob Tracking Workflows
Stage Precision » Stage Precision » Workflows » Blob Tracking Workflows
Within SP, there are 2 different types of blob tracking possible depending on the type of sensor Image Based Blob Tracking analyzes data from an image to detect a blob or an object of interest. This could be done with an standard color image or a black and white…
0.8.134 / 0.8.135
1.1.0
Optitrack (NatNet)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Optitrack (NatNet)
This is a native input for Optitrack NatNet data. *This is only available for Virtual Production, Tracking, Light Tracking, and Full license. Optitracks (NatNet) Setup Input Name Description Server IP This is the port that the data…
WiseHockey
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » WiseHockey
WiseHockey is a tracking solution that provides location information about the players and the puck in a ice hockey ring. *This is only available for Tracking, Light Tracking, Full, and Engineer license. Setup WiseHockey Name Description …
Pixotope Gateway
Stage Precision » Stage Precision » Views / Elements » IO Connections » Realtime Engine » Pixotope Gateway
Pixotope is a real-time rendering engine based on Unreal Engine for virtual studios, augmented reality, extended reality, mixed reality, and virtual production applications. This IO connection act as a wrapper to the Pixotope Gateway API. Pixotope Gateway …
1.1.68
Stage Precision » Changelog » 1.1.68
New Sensor integration: Ouster 3D Lidar New IO Connection: Aumovis Grass Valley Native RossTalk Pixotope API integration Erizos API integration Qsys ECP Integration Spatial Phidget MOT 1102 New Objects: Text object New Node: Debounce New Camera…
vMix
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » vMix
To control vMix from Stage Precision it´s necessary to activate the TCP API within vMix. Enable remote control within vMix Open the “Settings” in the upper right corner and navigate to “Web Controller”. Make sure that the “TCP…
Supported Tracking Protocols
Stage Precision » Stage Precision » Workflows » Camera Calibration » Supported Tracking Protocols
Supported tracking protocols for different calibration methods: *These protocols can also be used in combination! Example: Protocol “A” supports “Lens Calibration” but not “Tracking Calibration”. Protocol “B” supports…
Telegram Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Telegram Bot
With the Telegram Bot IO it´s possible to send notifications from SP directly into your Telegram messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. It´s also possible to send from Telegram a specific messages…
Pixera
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Pixera
PIXERA is a 64-bit media server system for real-time media processing and compositing and management, which is built around the theme of usability. Pixera Setup Name Description Update Handle Ids When pressing the button the handle Ids…
