The topic you requested could not be found.
Calibration
Stage Precision » Stage Precision » Views / Elements » Objects » Calibration
These are the different types of calibration screens availble: Infinite Board Multi Screen Single Screen
Calibration Tool
Stage Precision » Stage Precision » Views / Elements » IO Connections » Calibration Tool
World Calibration
Calibration Screens
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens
Multiscreen Single Screen Infinity Screen !It is extremely important that the settings in SP for the calibration screen for the size of the marker, starting marker ID, resolution of the screen, size of the screen are all configured to match what the real world…
Calibration Screen
Stage Precision » Stage Precision » Views / Elements » Objects » Utilities » Calibration Screen
Calibration Screen Setup Name Description Size The width and height of the screen can be added here in meters. Resolution The resolution in pixels width and height can be added here. Grid Size The number of…
Optitrack Calibration
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Calibration
The goal of the Optitrack Calibration is to calculate the relative positions of all the Optitrack Cameras in relationship to each other. There are different tools for calibrating multiple optitrack cameras through a wanding process to create one single Optitrack…
Camera Calibration
SP has several methods of Camera Calibration Tools depending on the need. Calibration Tools These tools can generate Lens Profiles and/or Alignment Profiles as well as position screens. Name Notes Generate Lens Profile Generate Alignment Profile…
Image Calibration Wizard
Stage Precision » Stage Precision » Workflows » Camera Calibration » Image Calibration Wizard
Interface A breakdown of the toolbar at the top of the Image Calibration Wizard: Switch to expand the list of images captured for observation The button to capture an image from the camera feed for observation Run…
FAQ Camera Calibration
Stage Precision » Stage Precision » Workflows » Camera Calibration » FAQ Camera Calibration
How many observations should I do for my lens? It’s very difficult to say, there isn’t one way that works for all lenses. A high quality broadcast lens may only need a calibration point for zoom at every 20% step and then each at 0% and 100% focus. On the…
Lens & Tracking Calibration Lens Calibration Tracking Alignment Alignment with Marker Simple Static Calibration Lens & Tracking Calibration
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Calibration Workflows » Simple Static Calibration
The Static Calibration tool is to provide a quick and easy way to quickly align a static camera that does not move or do any pan/tilt/roll. At the end of this calibration, the camera would be placed relative to the calibration screen. *There will be NO lens profile…
Switch Board
Stage Precision » Stage Precision » Actions » Switch Board
The Switch Board Action can be used to switch the actual or other Board panels. Select the target Board which should be switched to. Within the “Panel Instance” it´s possible to define if all or a specific Board panel should switch to the defined…
Infinite Board
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens » Infinite Board
The Infinite Board is similar to a Single Screen where it is used for a single flat screen. The difference between them is the pattern that is generated. For a Single Screen, the pattern is generated using a constant marker size. An Infinite Board generates…
Shield Board Interface
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Shield Board Interface
Within the Stage Precision board it´s possible adding an “Interface Object” to get access to some quick actions and to monitor the status of different Shield nodes. Add the Interface Object Drag and drop the Shield IO into the Board and select…
Board & Nodes
Stage Precision » Stage Precision » Views / Elements » Board & Nodes
Interface Camera Links Objects Nodes Calculate Nodes Math Nodes Convert Nodes Smoothing Nodes Colour Nodes Utility Nodes Text Nodes Event Nodes Generator Nodes Composition Nodes Board Object Selection Layout The board acts as a control panel. Within…
Virtual Camera Fly
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Virtual Camera Fly
Virtual Camera Fly is a function within Stage Precision to use full virtual camera animations or extend the actual tracked camera. The Live Input within Shield stays at the defined location and will manipulate the scale and perspective of the camera feed, as if it…
LOLED Virtual / LONET
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with incoming DMX values
Prepare the Fixtures to full desk controll Select the fixtures which should be calibrated and set the Mix parameter all to the max value to have full controll from the lighting desk. *By using a map input for this, simply change this values from your lighting desk.…
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with self-generated values
Instead of using the lighting desk to focus on the measurement point during the calibration process, it´s also possible to position the fixture directly from SP. Make sure that SP has the full control Bring all Mix parameter to the minimum. Start Batch…
Stage Precision » Stage Precision » Workflows » Camera Calibration » Lens & Tracking Calibration Wizard
Interface A breakdown of the toolbar at the top of the Calibration Wizard: Switch to view the list of observations that have been captured Switch to the capture mode Open the list of calibration screens …
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Board Object Selection Layout
Within Stage Precision the “Board” can also be used to create Layouts to select objects within the ObjectTree. 1.) Drag´n Drop a Object from the ObjectTree into a Board. 2.) Add this as “Interface”. 3.) Do this with multiple objects and…
1.1.46
Stage Precision » Changelog » 1.1.46
New Integrations: Indiemark Lens Encoder Indiemark 2 Lens Encoder Glassmark II Lens Encoder Websocket New Nodes: Fading MTC In New Features: New Camera calibration tool: Simple Static Calibration to calibrate a fix lens and align the camera with a single…
0.8.124
Stage Precision » Changelog » 0.8.124
Stage Precision 0.8.124 New Camera Calibration features: Camera Calibration Camera Reprojection with Board Camera Reprojection with Marker Board Reprojection General New Features: Stype Output supports now TC Webserver supports now Colorfield Webserver…
Technocrane UDP (SUPERTECHNO)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Technocrane UDP (SUPERTECHNO)
The Technocrane is a camera crane system, this is the input for the crane tracking system. *This is only available for Virtual Production, and Full license. Input Name Description Local Port This is the port that will receive data from…
Light Fixture
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Light Fixture
This is an interchangeable moving light fixture. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the…
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Camera
Camera Filter Distortion Viewer This places a standard camera in the 3D space. This camera can be set to a perspective or orthogonal view. Coordinates Name Description Position This will move the object along X, Y and Z axis in the…
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Technocrane Serial (SUPERTECHNO)
The Technocrane is a camera crane system, this is the input for the crane tracking system. *This is only available for Virtual Production, and Full license. Technocrane Serial Setup Name Description Port Don’t Connect Standard…
Camera View
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Camera View
Camera View Setup Name Description Camera The camera can be selected using the target button. Screen The calibration screen can be selected using the target button. Distance to Center This is the output…
Axis
Stage Precision » Stage Precision » Views / Elements » Objects » Axis
*This is only available for Virtual Production, Full, and Engineer license. See under Camera calibration: Linear Axis Rotator Axis 2D Axis
Cmotion
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Cmotion
*This is only available for Virtual Production, and Full license. Cmotion Setup Name Description Port Don’t Connect Standard Serial over Bluetooth Link (COM4) Standard Serial over Bluetooth Link (COM5) Baud Rate …
Yocto-RangeFinder
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Yocto » Yocto-RangeFinder
The Yocto-RangeFinder is a USB distance sensor (range finder). The Yocto-RangeFinder IO can be added with a click on the (+) within the IO Connections. Within the Inspector the Yocto-RangeFinder needs to know the connection mode (USB or Network) and the device…
0.8.126
Stage Precision » Changelog » 0.8.126
Stage Precision 0.8.126 New IO Connections: Monogram Creative Console Skaarhoj Controller Deltacast input card New Features: General add relative mode to XY Stick Undo function for container reset Usebility support calculation also in fields with mm and…
Spidercam (FRAME-B)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Spidercam (FRAME-B)
Spidercam is a cable camera system. Within Stage Precision it´s possible to read the position, rotation and lens data from a spidercam system. *This is only available for Virtual Production, and Full license. !Not each Spidercam product can send out tracking data.…
Laser Fixture
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Laser Fixture
This is a laser fixture object which has full parameter control. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the…
Shotover G1
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Shotover G1
Shotover G1 is a lightweight, weather resistant, gyro-stabilized gimbal platform. *This is only available for Virtual Production, and Full license. Shotover Name Description Local Port This is the port that will receive data from other…
0.8.128
Stage Precision » Changelog » 0.8.128
IO Connections: Qualisys Tracking Technocrane improvements to support 3-axes remote head LiveLink Support for UE 4.27.2 Camera Calibration / Lens Profile: new interpolation algorithm performance improvements for Distortion Viewer. Media Input /…
1.1.16 / 1.1.33
Stype (Stype HF)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Stype (Stype HF)
Stype is the combination of a RedSpy camera and follower which together can track objects and people within a space in XYZ directions. *This is only available for Virtual Production, and Full license. Stype Setup Input Name Description Local…
Image Sensor
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Image Sensor
For details on how to use this object to do blob tracking please refer to this page. Tools As an image based sensor, there is the option to utilize the workflow similar to those from camera calibration to locate / reposition the sensor’s coordinate. The…
CommonVisionCamera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » CommonVisionCamera
https://www.commonvisionblox.com/en/products/series/cvb-camerasuite/ For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer…
Galaxy Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Galaxy Camera
Support for GigE Cameras from Daheng Imaging For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer license. Tools As an image based sensor, there is the option to utilize the…
Light Tracking
Add/Setup Tracking Light Fixtures Define Measurement Points DMX Patch Calibration with incoming DMX values Calibration with self-generated values Live Control DMX Merge
Axis tools
Stage Precision » Stage Precision » Workflows » Camera Calibration » Axis tools
Axis is used to create a path of movement along an axis / track / spline based on encoder values and and image provider. If an object has multiple axes of movement, mutiple axes can be created one at a time and put one axis as a child of another to create a parent…
OpenVR (Vive & Oculus)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » OpenVR (Vive & Oculus)
This is a native input for OpenVR data. Before using the OpenVR input its necessary to modify SteamVR. OpenVR Setup Name Description Reconnect This button can be pressed to reconnect with the VR headset. Connected When…
Alignment Profile
Stage Precision » Stage Precision » Views / Elements » Pool » Alignment Profile
This is a profile for aligning the tracking system’s incoming data to the SP world coordinate. This is generated from tools under the Camera Calibration workflow. For more information, please click here.
Slider
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Slider
This acts as a slider on a Midi controller or lighting desk. This virtual slider can be mapped to an output and/or mapped to an input to be influenced by an external device. Slider Setup Name Description Type Horizontal – …
Remote control Shield Settings Remote control Parameter Remote control Material Parameter Remote control Blueprint Variables Remote control Blueprint Events Remote control Blueprint Functions Remote control Level Remote control Editor Remote control console…
Tracking Alignment
Antilatency
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Antilatency
This is a native input for Antilatency tracking data. Antilatency is an inside-out tracking system provider for VR/AR, Virtual Production, MoCap, Drones and Robotics. !AntilatencyService v4.0.0 needs to run and connected on the same computere where SP is…
1.1.0
F4 (Mo-Sys)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » F4 (Mo-Sys)
Mo-Sys are camera tracking and robotic tracking systems, this IO connection is an input and output for the tracking data. *This is only available for Virtual Production, and Full license. !Map/Node Outputs can be used not only to send the F4 protocol to different…
1.1.128
Stage Precision » Changelog » 1.1.128
New Sensors / IO Connections: Robosense 3D lidar Canon CV Protocol New Maps: Visca Map Joystick input for PTZ Cameras Visca Map input for Target Frame New Features: New Volume Filter – Scale New Volume Filter – Offset Add calibration tools for…
Utilities
Calibration Screen Measurement Line Measurement Point
Optitrack Analysis
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Analysis
Analyse Recording This tool is used to record some tracking data and this tracking data can be used at a later time to analyse the accuracy of the tracking system. It is useful to help analyse whether some cameras have shifted over time since the last calbration, and…
Camera Reposition Tools
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools
On top of doing a Lens Calibration and Tracking Alignment, the camera object has some extra tools to help reposition multiple screens based on the captured images. Prerequisites: Tracking system data into SP Media input into SP A camera object within…
Screens Alignment
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Screens Alignment
The Screen Alignment Reposition Tool is used to reposition multiple screens based on a known calibrated tracked camera. *For this tool to work, the tracked camera needs at least Pan/Tilt encoders, but ideally a full 6DoF tracking system will generate better…
Orbbec Femto Mega
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Orbbec Femto Mega
The Femto Mega from Orbbec is a multi-mode Depth and RGB camera with real-time streaming over Ethernet or USB connections. This sensor object is supporting the image based blob tracking as well as the point cloud blob tracking workflows. Setup First add the Orbbec…
Optitrack (NatNet)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Optitrack (NatNet)
This is a native input for Optitrack NatNet data. *This is only available for Virtual Production, Tracking, Light Tracking, and Full license. Optitracks (NatNet) Setup Input Name Description Server IP This is the port that the data…
Sony FR7
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Sony FR7
Prepare the camera First the freeD feedback output needs to be activated Make sure, that this values are matching with the SP settings: - Camera ID - Destination IP - Destination Port Enable Visca for the FR7 Enable Tally over Visca Range the Zoom and…
1.1.90-92
Stage Precision » Changelog » 1.1.90-92
New Objects: Orbbec Femto Mega StreamDeck New IO Connection: Phiget Rel1100 ADM-OSC Kinesys New Features: All tracking map inputs have now delays for position, rotation and all additional custom data like zoom, focus etc. New Camera calibration…
1.1.68
Stage Precision » Changelog » 1.1.68
New Sensor integration: Ouster 3D Lidar New IO Connection: Aumovis Grass Valley Native RossTalk Pixotope API integration Erizos API integration Qsys ECP Integration Spatial Phidget MOT 1102 New Objects: Text object New Node: Debounce New Camera…
Measurement Point
Stage Precision » Stage Precision » Views / Elements » Objects » Utilities » Measurement Point
Measurement Points are reference points which can be used for Lens Calibration, Tracking calibration and to calibrate Light Fixtures. Measurement Points can be added within the Object Tree to find in the menu “Utilities”. *Rename the Measurement Points…
Reposition from Screens
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Reposition from Screens
The Reposition from Screen Tool is used to reposition a camera based on a known / pre-defined location of a screen. This tool can be used on a camera with a tracking system as well as static camera with no tracking system. Prerequisites At least one calibration…
1.1.112
Stage Precision » Changelog » 1.1.112
New IO Connections: Blackmagic Design Smart Videohub 10×10 Blackmagic Design Smart Videohub 80×80 Blackmagic Design Smart Videohub 120×120 New PTZ Objects: Panasonic UE 100 Panasonic UE 150 Panasonic UE 160 Sony BRC-X1000 Sony…
Winch
Stage Precision » Stage Precision » Views / Elements » Objects » Kinetic » Winch
This is a virtual representation of a motorized winch, with a winch body, chain and hook. Objects attached to the hook and controlled by the movement of the winch. *This is only available for Kinetic Control, Full, and Engineer license. The winch is able to receive…
Area
Stage Precision » Stage Precision » Views / Elements » Objects » Logic » Area
This is an area within the virtual 3D space and has the ability to detect virtual objects entering and leaving the space. This can be used to output a variety of messages and triggers internally and externally from Stage Precision. Coordinates Name…
Optitrack Recalibration
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Recalibration
Recalibration can be done if some cameras have shifted slightly or a new camera is added into an already calibrated system. This is a tool to provide a faster method to calibrate a system based on the assumption that the majority of the system is still in a good state.…
TrackMen
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » TrackMen
TrackMen has multiple 3D real-timeTracking solutions among other things for camera tracking. *This is only available for Virtual Production, and Full license. Add a connection to TrackMen The TrackMen IO can be added with a click on the (+) within the IO…
Shield Plugin Settings Shield Settings Pixel Format / Color Space Lock Shield Shield actor Blueprints Blueprints Shield Settings Blueprints Shield Actor Blueprints Utilities Render Passes / Object Lists Background Foreground Garbage…
Hokuyo UST-10LX
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Hokuyo UST-10LX
The UST-10LX is a 2D LiDAR sensor. For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer license. Add the Sensor To add a connection to a UST-10LX, open the Object Tree and add…
WiseHockey
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » WiseHockey
WiseHockey is a tracking solution that provides location information about the players and the puck in a ice hockey ring. *This is only available for Tracking, Light Tracking, Full, and Engineer license. Setup WiseHockey Name Description …
TiMax Tracker d4
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » TiMax Tracker d4
This is an integration with the TiMax Tracker which is a positional tracking system based on UWB technology. *This is only available for Tracking, Interactive, and Full license. TiMax Setup Input Name Description Port This is the port…
Panasonic UE 100 / UE 150 / UE 160
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Panasonic UE 100 / UE 150 / UE 160
For the general configuration on how to work with a PTZ camera, please refer to here. In this page, we will be mainly focusing on how to setup a Panasonic PTZ camera, specifically the UE 100, UE 150, and the UE160. Configure PTZ camera to send out FreeD Data In…
Kinect
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Kinect
This is the protocol for receiving Kinect skeleton data from a Kinect V2. Kinect Setup Calibration Name Description Offset Pos Any positional offset to the data can be set. Offset Scale Any scale offset to the data can…
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Skeleton
This is a virtual representation of the human body, with 24 joints that correspond to points on the body. Each of the joints have 11 different properties; colour, depth, camera and orientation in the X, Y and Z axis. Coordinates Name Description…
Spotlight
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Spotlight
This is a set light fixture that is usually used to light an object or person. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system.…
Supported Tracking Protocols
Stage Precision » Stage Precision » Workflows » Camera Calibration » Supported Tracking Protocols
Supported tracking protocols for different calibration methods: *These protocols can also be used in combination! Example: Protocol “A” supports “Lens Calibration” but not “Tracking Calibration”. Protocol “B” supports…
FreeD UDP
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » FreeD UDP
FreeD is a UDP protocol that can be used to take in and output positional data of cameras. *This is only available for Virtual Production, and Full license. FreeD Setup Input Name Description Local Port This is the port that will receive…
Reposition from Marker
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Reposition from Marker
The Reposition from Marker Tool is used to reposition a camera based on a predefined markers in 3D space instead of patterns on a screen. This tool can be used on a camera with a tracking system as well as static camera with no tracking system. Prerequisites A…
Web Target (link)
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Button » Web Target (link)
A Web Target (link) can be assigned to a Button to open a webpage if the board is used as webserver. Open the container web. External link Define the link adress inkl. “http://” to open this if the button is pressed on a webserver. Open now this…
Azure Kinect
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Azure Kinect
To use the Azure Kinect IO connection, the kinect sensor(s) must first be added using the + button. !Azure Kinect SDK Version 1.4.1 (Firmware 1.6.110079014) is supported. Kinect Setup Coordinates Name Description Position The…
Image Based Blob Tracking
Optitrack Alignment
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Alignment
Once all the cameras has been calibrated and their relative position between each other has been reconstructed, the next step is to offset / translate the entire group of cameras so the tracking volume is aligned with the 3D space within SP. There are several options…
IO Connections
IO Connections are input and output protocols and/or devices which is how tracking, movement and trigger events are communicated in and out of Stage Precision. IO Connections can be added using the + button. 2D Tracking 3D Tracking Audio Camera…
Pixera
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Pixera
PIXERA is a 64-bit media server system for real-time media processing and compositing and management, which is built around the theme of usability. Pixera Setup Name Description Update Handle Ids When pressing the button the handle Ids…
PTZ
All of the manufacturer specific PTZ camera objects would be organized under this category. Currently, we have the following manufacturer specific PTZ cameras: Panasonic UE 100 Panasonic UE 150 Panasonic UE 160 Sony BRC-X1000 Sony FR7 !The Sony camera…
Webserver
Stage Precision » Stage Precision » General settings » Project Settings » Webserver
Boards or Frames inside a Board can be puplished as website. The following interface elements are supported: Buttons ColorField Slider Image Label Frames Textfield Status Indicator Parameter References Remote/Content Remote/Layer Remote/Timeline …
0.8.118
Stage Precision » Changelog » 0.8.118
New Features: - #300 General – TimeManager Monitor - #294 General – Multi Inspector - #293 General – Multi Board - #304 ObjectTree – Replace object function - #298 ObjectTree – Splines edit/add subpoints - #303 IOConnections – Input…
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Tracking Light Fixture
The Tracking Light Fixture is an object to follow a Target and drive a real moving head fixture in real time. It can send and receive DMX data over ArtNet and/or sACN. *This is only available for Light Tracking, Full, and Engineer license. This object can not only…
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Image
An image or logo can be loaded into the board. Image Setup Name Description Image Path An image can be uploaded from your computer. Layout Name Description Colour This is the colour of the…
Content
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Remote Widgets » Content
This widget allows users to load a web link within the web board. Name Description Url Define the URL to load for the widget in the web board How the widget looks like on the web board:
Reference
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Interface » Reference
This is an interface reference any parameter of any object can be linked to this reference and displayed within the board. Reference Setup Name Description Label The label name will be displayed here and can be edited if the…
Log Message
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Log Message
This logs a massage from any output. Log Setup Name Description Message This is where the message is displayed from the output node. Layout Name Description Position The position of the node on the…
TimeStamp
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » TimeStamp
This outputs a timestamp (hours:minutes:seconds:frames). TimeStamp Setup Name Description Time Stamp This is a float value output. Time Stamp as String This is a message output. Layout Name…
KeyStroke
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » KeyStroke
This node generates integer values for each key on the keyboard. KeyStroke Setup Name Description Keystroke An integer value is generated and output each time a key is pressed. Layout Name Description …
