Search
Calibration Screen
Stage Precision » Stage Precision » Views / Elements » Objects » Utilities » Calibration Screen
Calibration Screen Setup Name Description Size The width and height of the screen can be added here in meters. Resolution The resolution in pixels width and height can be added here. Grid Size The number of…
Calibration
Stage Precision » Stage Precision » Views / Elements » Objects » Calibration
These are the different types of calibration screens availble: Infinite Board Multi Screen Single Screen
Calibration Tool
Stage Precision » Stage Precision » Views / Elements » IO Connections » Calibration Tool
World Calibration
Calibration Screens
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens
Multiscreen Single Screen Infinity Screen !It is extremely important that the settings in SP for the calibration screen for the size of the marker, starting marker ID, resolution of the screen, size of the screen are all configured to match what the real world…
Optitrack Calibration
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Calibration
The goal of the Optitrack Calibration is to calculate the relative positions of all the Optitrack Cameras in relationship to each other. There are different tools for calibrating multiple optitrack cameras through a wanding process to create one single Optitrack…
Camera Calibration
SP has several methods of Camera Calibration Tools depending on the need. Calibration Tools These tools can generate Lens Profiles and/or Alignment Profiles as well as position screens. Name Notes Generate Lens Profile Generate Alignment Profile…
Image Calibration Wizard
Stage Precision » Stage Precision » Workflows » Camera Calibration » Image Calibration Wizard
Interface A breakdown of the toolbar at the top of the Image Calibration Wizard: Switch to expand the list of images captured for observation The button to capture an image from the camera feed for observation Run…
FAQ Camera Calibration
Stage Precision » Stage Precision » Workflows » Camera Calibration » FAQ Camera Calibration
How many observations should I do for my lens? It’s very difficult to say, there isn’t one way that works for all lenses. A high quality broadcast lens may only need a calibration point for zoom at every 20% step and then each at 0% and 100% focus. On the…
Lens & Tracking Calibration Lens Calibration Tracking Alignment Alignment with Marker Simple Static Calibration Lens & Tracking Calibration
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Calibration Workflows » Simple Static Calibration
The Static Calibration tool is to provide a quick and easy way to quickly align a static camera that does not move or do any pan/tilt/roll. At the end of this calibration, the camera would be placed relative to the calibration screen. *There will be NO lens profile…
Single Screen
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens » Single Screen
Setting Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the settings under “Display”…
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with incoming DMX values
Prepare the Fixtures to full desk controll Select the fixtures which should be calibrated and set the Mix parameter all to the max value to have full controll from the lighting desk. *By using a map input for this, simply change this values from your lighting desk.…
Stage Precision » Stage Precision » Workflows » Light Tracking » Calibration with self-generated values
Instead of using the lighting desk to focus on the measurement point during the calibration process, it´s also possible to position the fixture directly from SP. Make sure that SP has the full control Bring all Mix parameter to the minimum. Start Batch…
Stage Precision » Stage Precision » Workflows » Camera Calibration » Lens & Tracking Calibration Wizard
Interface A breakdown of the toolbar at the top of the Calibration Wizard: Switch to view the list of observations that have been captured Switch to the capture mode Open the list of calibration screens …
Image Sensor
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Image Sensor
For details on how to use this object to do blob tracking please refer to this page. Tools As an image based sensor, there is the option to utilize the workflow similar to those from camera calibration to locate / reposition the sensor’s coordinate. The…
CommonVisionCamera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » CommonVisionCamera
https://www.commonvisionblox.com/en/products/series/cvb-camerasuite/ For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer…
Galaxy Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Galaxy Camera
Support for GigE Cameras from Daheng Imaging For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer license. Tools As an image based sensor, there is the option to utilize the…
Axis tools
Stage Precision » Stage Precision » Workflows » Camera Calibration » Axis tools
Axis is used to create a path of movement along an axis / track / spline based on encoder values and and image provider. If an object has multiple axes of movement, mutiple axes can be created one at a time and put one axis as a child of another to create a parent…
1.1.0
Utilities
Calibration Screen Measurement Line Measurement Point
Sony FR7
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Sony FR7
Prepare the camera First the freeD feedback output needs to be activated Make sure, that this values are matching with the SP settings: - Camera ID - Destination IP - Destination Port Enable Visca for the FR7 Enable Tally over Visca Range the Zoom and…
1.1.128
Stage Precision » Changelog » 1.1.128
New Sensors / IO Connections: Robosense 3D lidar Canon CV Protocol New Maps: Visca Map Joystick input for PTZ Cameras Visca Map input for Target Frame New Features: New Volume Filter – Scale New Volume Filter – Offset Add calibration tools for…
Image Based Blob Tracking
Screens Alignment
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Screens Alignment
The Screen Alignment Reposition Tool is used to reposition multiple screens based on a known calibrated tracked camera. *For this tool to work, the tracked camera needs at least Pan/Tilt encoders, but ideally a full 6DoF tracking system will generate better…
Tracking Alignment
Reposition from Screens
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Reposition from Screens
The Reposition from Screen Tool is used to reposition a camera based on a known / pre-defined location of a screen. This tool can be used on a camera with a tracking system as well as static camera with no tracking system. Prerequisites At least one calibration…
Camera View
Stage Precision » Stage Precision » Views / Elements » Board & Nodes » Utility Nodes » Camera View
Camera View Setup Name Description Camera The camera can be selected using the target button. Screen The calibration screen can be selected using the target button. Distance to Center This is the output…
1.1.46
Stage Precision » Changelog » 1.1.46
New Integrations: Indiemark Lens Encoder Indiemark 2 Lens Encoder Glassmark II Lens Encoder Websocket New Nodes: Fading MTC In New Features: New Camera calibration tool: Simple Static Calibration to calibrate a fix lens and align the camera with a single…
Stage Precision » Stage Precision » Views / Elements » Objects » Tracked Objects » Camera
Camera Filter Distortion Viewer This places a standard camera in the 3D space. This camera can be set to a perspective or orthogonal view. Coordinates Name Description Position This will move the object along X, Y and Z axis in the…
On top of doing a Lens Calibration and Tracking Alignment, the camera object has some extra tools to help reposition multiple screens based on the captured images. Prerequisites: Tracking system data into SP Media input into SP A camera object within…
Orbbec Femto Mega
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Orbbec Femto Mega
The Femto Mega from Orbbec is a multi-mode Depth and RGB camera with real-time streaming over Ethernet or USB connections. This sensor object is supporting the image based blob tracking as well as the point cloud blob tracking workflows. Power Up the Sensor Please…
1.1.90-92
Stage Precision » Changelog » 1.1.90-92
New Objects: Orbbec Femto Mega StreamDeck New IO Connection: Phiget Rel1100 ADM-OSC Kinesys New Features: All tracking map inputs have now delays for position, rotation and all additional custom data like zoom, focus etc. New Camera calibration…
1.1.112
Stage Precision » Changelog » 1.1.112
New IO Connections: Blackmagic Design Smart Videohub 10×10 Blackmagic Design Smart Videohub 80×80 Blackmagic Design Smart Videohub 120×120 New PTZ Objects: Panasonic UE 100 Panasonic UE 150 Panasonic UE 160 Sony BRC-X1000 Sony…
1.1.68
Stage Precision » Changelog » 1.1.68
New Sensor integration: Ouster 3D Lidar New IO Connection: Aumovis Grass Valley Native RossTalk Pixotope API integration Erizos API integration Qsys ECP Integration Spatial Phidget MOT 1102 New Objects: Text object New Node: Debounce New Camera…
1.1.16 / 1.1.33
Reposition from Marker
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Reposition from Marker
The Reposition from Marker Tool is used to reposition a camera based on a predefined markers in 3D space instead of patterns on a screen. This tool can be used on a camera with a tracking system as well as static camera with no tracking system. Prerequisites A…
Multiscreen
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens » Multiscreen
A calibration multiscreen can be used to calibrate curved or other shaped LED-Walls. Basic configuration of defining the screen size, resolution and marker IDs are the same as a Single Screen. For details please refer to here. *You can export a Multiscreen as FBX …
Light Tracking
Add/Setup Tracking Light Fixtures Define Measurement Points DMX Patch Calibration with incoming DMX values Calibration with self-generated values Live Control DMX Merge
Alignment Profile
Stage Precision » Stage Precision » Views / Elements » Pool » Alignment Profile
This is a profile for aligning the tracking system’s incoming data to the SP world coordinate. This is generated from tools under the Camera Calibration workflow. For more information, please click here.
Optitrack Analysis
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Analysis
Analyse Recording This tool is used to record some tracking data and this tracking data can be used at a later time to analyse the accuracy of the tracking system. It is useful to help analyse whether some cameras have shifted over time since the last calbration, and…
Antilatency
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Antilatency
This is a native input for Antilatency tracking data. Antilatency is an inside-out tracking system provider for VR/AR, Virtual Production, MoCap, Drones and Robotics. !AntilatencyService v4.0.0 needs to run and connected on the same computere where SP is…
Measurement Point
Stage Precision » Stage Precision » Views / Elements » Objects » Utilities » Measurement Point
Measurement Points are reference points which can be used for Lens Calibration, Tracking calibration and to calibrate Light Fixtures. Measurement Points can be added within the Object Tree to find in the menu “Utilities”. *Rename the Measurement Points…
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Technocrane Serial (SUPERTECHNO)
The Technocrane is a camera crane system, this is the input for the crane tracking system. *This is only available for Virtual Production, and Full license. Technocrane Serial Setup Name Description Port Don’t Connect Standard…
0.8.126
Stage Precision » Changelog » 0.8.126
Stage Precision 0.8.126 New IO Connections: Monogram Creative Console Skaarhoj Controller Deltacast input card New Features: General add relative mode to XY Stick Undo function for container reset Usebility support calculation also in fields with mm and…
Optitrack Recalibration
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Recalibration
Recalibration can be done if some cameras have shifted slightly or a new camera is added into an already calibrated system. This is a tool to provide a faster method to calibrate a system based on the assumption that the majority of the system is still in a good state.…
Cmotion
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Cmotion
*This is only available for Virtual Production, and Full license. Cmotion Setup Name Description Port Don’t Connect Standard Serial over Bluetooth Link (COM4) Standard Serial over Bluetooth Link (COM5) Baud Rate …
Pixera
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Pixera
PIXERA is a 64-bit media server system for real-time media processing and compositing and management, which is built around the theme of usability. Pixera Setup Name Description Update Handle Ids When pressing the button the handle Ids…
Hokuyo UST-10LX
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Hokuyo UST-10LX
The UST-10LX is a 2D LiDAR sensor. For details on how to use this object to do blob tracking please refer to this page. *This is only available for Tracking, Full, and Engineer license. Add the Sensor To add a connection to a UST-10LX, open the Object Tree and add…
WiseHockey
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » WiseHockey
WiseHockey is a tracking solution that provides location information about the players and the puck in a ice hockey ring. *This is only available for Tracking, Light Tracking, Full, and Engineer license. Setup WiseHockey Name Description …
TiMax Tracker d4
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » TiMax Tracker d4
This is an integration with the TiMax Tracker which is a positional tracking system based on UWB technology. *This is only available for Tracking, Interactive, and Full license. TiMax Setup Input Name Description Port This is the port…
Panasonic UE 100 / UE 150 / UE 160
Stage Precision » Stage Precision » Views / Elements » Objects » PTZ » Panasonic UE 100 / UE 150 / UE 160
For the general configuration on how to work with a PTZ camera, please refer to here. In this page, we will be mainly focusing on how to setup a Panasonic PTZ camera, specifically the UE 100, UE 150, and the UE160. Configure PTZ camera to send out FreeD Data In…
Supported Tracking Protocols
Stage Precision » Stage Precision » Workflows » Camera Calibration » Supported Tracking Protocols
Supported tracking protocols for different calibration methods: *These protocols can also be used in combination! Example: Protocol “A” supports “Lens Calibration” but not “Tracking Calibration”. Protocol “B” supports…
Axis
Stage Precision » Stage Precision » Views / Elements » Objects » Axis
*This is only available for Virtual Production, Full, and Engineer license. See under Camera calibration: Linear Axis Rotator Axis 2D Axis
Spidercam (FRAME-B)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Spidercam (FRAME-B)
Spidercam is a cable camera system. Within Stage Precision it´s possible to read the position, rotation and lens data from a spidercam system. *This is only available for Virtual Production, and Full license. !Not each Spidercam product can send out tracking data.…
0.8.124
Stage Precision » Changelog » 0.8.124
Stage Precision 0.8.124 New Camera Calibration features: Camera Calibration Camera Reprojection with Board Camera Reprojection with Marker Board Reprojection General New Features: Stype Output supports now TC Webserver supports now Colorfield Webserver…
Azure Kinect
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Azure Kinect
To use the Azure Kinect IO connection, the kinect sensor(s) must first be added using the + button. !Azure Kinect SDK Version 1.4.1 (Firmware 1.6.110079014) is supported. Kinect Setup Coordinates Name Description Position The…
Optitrack Alignment
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Volume » Optitrack Alignment
Once all the cameras has been calibrated and their relative position between each other has been reconstructed, the next step is to offset / translate the entire group of cameras so the tracking volume is aligned with the 3D space within SP. There are several options…
IO Connections
IO Connections are input and output protocols and/or devices which is how tracking, movement and trigger events are communicated in and out of Stage Precision. IO Connections can be added using the + button. 2D Tracking 3D Tracking Audio Camera…
PTZ
All of the manufacturer specific PTZ camera objects would be organized under this category. Currently, we have the following manufacturer specific PTZ cameras: Panasonic UE 100 Panasonic UE 150 Panasonic UE 160 Sony BRC-X1000 Sony FR7 !The Sony camera…
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Tracking Light Fixture
The Tracking Light Fixture is an object to follow a Target and drive a real moving head fixture in real time. It can send and receive DMX data over ArtNet and/or sACN. *This is only available for Light Tracking, Full, and Engineer license. This object can not only…
Laser Fixture
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Laser Fixture
This is a laser fixture object which has full parameter control. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the…
Optitrack Volume
Optitrack Volume is the representation of the tracking area from a group of optitrack cameras that have been calibrated. *This is only available for Tracking, Light Tracking, Full, and Engineer license. In order to have a working optitrack volume, the following steps…
Leica Disto
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Leica Disto
Lecia Disto Setup Name Description Measure Polar Device The device name will be displayed here when connected. Test Message Pressing the button will test the communication message. OSC Input…
OpenVR (Vive & Oculus)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » OpenVR (Vive & Oculus)
This is a native input for OpenVR data. Before using the OpenVR input its necessary to modify SteamVR. OpenVR Setup Name Description Reconnect This button can be pressed to reconnect with the VR headset. Connected When…
Technocrane UDP (SUPERTECHNO)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Technocrane UDP (SUPERTECHNO)
The Technocrane is a camera crane system, this is the input for the crane tracking system. *This is only available for Virtual Production, and Full license. Input Name Description Local Port This is the port that will receive data from…
Blacktrax (RTTrPM)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Blacktrax (RTTrPM)
This is a native input for Blacktrax tracking data. *This is only available for Tracking, Light Tracking, and Full license. Blacktrax (RTTrPM) Setup Input Name Description Multicast Connection When on, data can be sent to multiple…
Shotover G1
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Shotover G1
Shotover G1 is a lightweight, weather resistant, gyro-stabilized gimbal platform. *This is only available for Virtual Production, and Full license. Shotover Name Description Local Port This is the port that will receive data from other…
0.8.128
Stage Precision » Changelog » 0.8.128
IO Connections: Qualisys Tracking Technocrane improvements to support 3-axes remote head LiveLink Support for UE 4.27.2 Camera Calibration / Lens Profile: new interpolation algorithm performance improvements for Distortion Viewer. Media Input /…
Yocto-RangeFinder
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Yocto » Yocto-RangeFinder
The Yocto-RangeFinder is a USB distance sensor (range finder). The Yocto-RangeFinder IO can be added with a click on the (+) within the IO Connections. Within the Inspector the Yocto-RangeFinder needs to know the connection mode (USB or Network) and the device…
Focusing on Points
Stage Precision » Stage Precision » Workflows » Camera Calibration » Camera Reposition Tools » Focusing on Points
The Focusing on Points Reposition Tool is used to update an existing Alignment Profile of a tracked camera. Typically this is used when the already aligned tracking system has been nudged / shifted slightly and only want to do a quick re-alignment. Prerequisites A…
Optitrack (NatNet)
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Optitrack (NatNet)
This is a native input for Optitrack NatNet data. *This is only available for Virtual Production, Tracking, Light Tracking, and Full license. Optitracks (NatNet) Setup Input Name Description Server IP This is the port that the data…
PSN IN
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » PosiStageNet (PSN) » PSN IN
This is the input protocol for PosiStageNet data which is positional tracking data of objects. PSN IN Setup Input Name Description Multicast Connection When on, data can be sent to multiple recipients. Multicast Target IP …
Kinexon
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Kinexon
This is a positional tracking system that is able to track XYZ position and rotation. It is a UWB based system. *This is only available for Tracking, Light Tracking, and Full license. Kinexon Setup Input Name Description Server IP This is…
Pozyx
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Pozyx
This is an ultra-wideband software and hardware designed to accurately track moving objects within a space. *This is only available for Tracking, Light Tracking, and Full license. Pozyx Setup Name Description Server IP This is where the…
Slack Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Slack Bot
With the Slack Bot IO it´s possible to send notifications from SP directly into your Slack messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. Prepare Slack It´s necessary to prepare Slack before using this…
Light Fixture
Stage Precision » Stage Precision » Views / Elements » Objects » Fixture » Light Fixture
This is an interchangeable moving light fixture. Coordinates Name Description Position This will move the object along X, Y and Z axis in the local space. Scale Scale of the coordinate system. To scale the Object check the…
TrackMen
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » TrackMen
TrackMen has multiple 3D real-timeTracking solutions among other things for camera tracking. *This is only available for Virtual Production, and Full license. Add a connection to TrackMen The TrackMen IO can be added with a click on the (+) within the IO…
Sewio
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Sewio
Sewio is an indoor tracking data, using ankers and tags. This IO Connection is able to take in this tracking data. *This is only available for Tracking, Light Tracking, and Full license. Sewio Setup Server Name Description Server IP This…
Stype (Stype HF)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Stype (Stype HF)
Stype is the combination of a RedSpy camera and follower which together can track objects and people within a space in XYZ directions. *This is only available for Virtual Production, and Full license. Stype Setup Input Name Description Local…
Perception Neuron
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Perception Neuron
Perception neuron is a motion capture suit with skeleton data. The IO connection takes in the perception neuron data. Perception Neuron Setup Name Description Server IP This is where the IP address of the server can be added. …
FreeD UDP
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » FreeD UDP
FreeD is a UDP protocol that can be used to take in and output positional data of cameras. *This is only available for Virtual Production, and Full license. FreeD Setup Input Name Description Local Port This is the port that will receive…
Optitrack Camera Setup
Telegram Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Telegram Bot
With the Telegram Bot IO it´s possible to send notifications from SP directly into your Telegram messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. It´s also possible to send from Telegram a specific messages…
Vertex Commands
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Vertex Commands
++++h2. Input Name Description Local Port This is the port that will receive data from other devices. Is Bound This will be on when the IO connection is bound to a network. Multicast Connection When on, data…
F4 (Mo-Sys)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » F4 (Mo-Sys)
Mo-Sys are camera tracking and robotic tracking systems, this IO connection is an input and output for the tracking data. *This is only available for Virtual Production, and Full license. !Map/Node Outputs can be used not only to send the F4 protocol to different…
Kinect
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Kinect
This is the protocol for receiving Kinect skeleton data from a Kinect V2. Kinect Setup Calibration Name Description Offset Pos Any positional offset to the data can be set. Offset Scale Any scale offset to the data can…
Infinite Board
Stage Precision » Stage Precision » Workflows » Camera Calibration » Calibration Screens » Infinite Board
The Infinite Board is similar to a Single Screen where it is used for a single flat screen. The difference between them is the pattern that is generated. For a Single Screen, the pattern is generated using a constant marker size. An Infinite Board generates…
Optitrack Camera
Stage Precision » Stage Precision » Views / Elements » Objects » Sensors » Optitrack Camera
Optitrack provides a wide range of camera sensors for tracking purposes. SP supports the Optitrack Prime and Slim cameras. *This is only available for Tracking, Light Tracking, Full, and Engineer license. Adding the Sensor To add a connection to an Optitrack camera,…
Optitrack Camera
Stage Precision » Stage Precision » Views / Elements » IO Connections » 2D Tracking » Optitrack Camera
This is the Camera SDK software which provides 2D camera object data. Optitrack Camera Setup Name Description Status The status of the incoming data will be displayed here. Is Running When on, data is being recieved.…
Point Cloud Blob Tracking
Stage Precision » Stage Precision » Workflows » Blob Tracking Workflows » Point Cloud Blob Tracking
There are different ways to get tracking information within SP. One of them is to extract infromation from a set of point cloud data and do blob tracking from that. There are in general 2 main groups of point cloud that SP can process to do blob tracking on. They are…
VLC
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » VLC
To control VLC from Stage Precision it´s necessary to define some settings first. Prepare VLC for remote control 1. Open the preferences 2. Change the “show settings” in the lower right corner select “All” 3. Activate Web …
Remote Settings
Shield for Unreal » Settings & Functions (UE5) » Remote Settings
In order to allow parameters to be remotely controlled via Shield, a Remote Control Preset needs to be created and assigned. Details are similar to how it is done in UE4. Refer to here more information. *Remember to keep the Remote Control Preset window open in…
Compositing (Combined)
Shield for Unreal » Setting & Functions (v0.8) » Render Passes / Object Lists » Compositing (Combined)
!This option is only available by using a Shield actor. The compositing (combined) added the different passes to each other. The option “Compositing Order” is to be found within the Shield Actor. Different blend modes can be chosen. These define how…
