Arithmetic & Assignment Operators
Operator Definition
+ Addition between x and y. (eg: x + y)
Subtraction between x and y. (eg: x – y)
* Multiplication between x and y. (eg: x * y)
/ Division between x and y. (eg: x / y)
% Modulus of x with respect to y. (eg: x % y)
^ x to the power of y. (eg: x ^ y)
:= Assign the value of x to y. Where y is either a variable or vector type. (eg: y := x)
+= Increment x by the value of the expression on the right and side. Where x is either a variable or vector type. (eg: x += abs(y – z))
-= Decrement x by the value of the expression on the right hand side. Where x is either a variable or vector type. (eg: x[i] -= abs(y + z))
*= Assign the multiplication of x by the value of the expression on the righthand side to x. Where x is either a variable or vector type. (eg: x *= abs(y / z))
/= Assign the division of x by the value of the expression on the right-hand side to x. Where x is either a variable or vector type. (eg: x[i + j] /= abs(y * z))
%= Assign x modulo the value of the expression on the right hand side to x. Where x is either a variable or vector type. (eg: x2 %= y ^ 2)
Equalities & Inequalities
Operator Definition
= or == True only if x is strictly equal to y. (eg: x = y or x == y)
<> or != True only if x does not equal y. (eg: x <> y or x != y)
< True only if x is less than y. (eg: x < y)
<= True only if x is less than or equal to y. (eg: x <= y)
> True only if x is greater than y. (eg: x > y)
>= True only if x greater than or equal to y. (eg: x >= y)
Boolean Operations
Operator Definition
true True state or any value other than zero (typically 1).
false False state, value of exactly zero.
and Logical AND, True only if x and y are both true. (eg: x and y)
mand Multi-input logical AND, True only if all inputs are true. Left to right short-circuiting of expressions. (eg: mand(x > y, z < w, u or v, w and x))
mor Multi-input logical OR, True if at least one of the inputs are true. Left to right short-circuiting of expressions. (eg: mor(x > y, z < w, u or v, w and x))
nand Logical NAND, True only if either x or y is false. (eg: x nand y)
nor Logical NOR, True only if the result of x or y is false (eg: x nor y)
not Logical NOT, Negate the logical sense of the input. (eg: not(x and y) == x nand y)
or Logical OR, True if either x or y is true. (eg: x or y)
xor Logical XOR, True only if the logical states of x and y differ. (eg: x xor y)
xnor Logical XNOR, True iff the biconditional of x and y is satisfied. (eg: x xnor y)
& Similar to AND but with left to right expression short circuiting optimisation. (eg: (x & y) == (y and x))
Similar to OR but with left to right expression short circuiting optimisation. (eg: (x ❘ y) == (y or x))
General Purpose Functions
Function Definition
abs Absolute value of x. (eg: abs(x))
avg Average of all the inputs. (eg: avg(x,y,z,w,u,v) == (x + y + z + w + u + v) / 6)
ceil Smallest integer that is greater than or equal to x.
clamp Clamp x in range between r0 and r1, where r0 < r1. (eg: clamp(r0,x,r1))
equal Equality test between x and y using normalised epsilon
erf Error function of x. (eg: erf(x))
erfc Complimentary error function of x. (eg: erfc(x))
exp e to the power of x. (eg: exp(x))
expm1 e to the power of x minus 1, where x is very small. (eg: expm1(x))
floor Largest integer that is less than or equal to x. (eg: floor(x))
frac Fractional portion of x. (eg: frac(x))
hypot Hypotenuse of x and y (eg: hypot(x,y) = sqrt(x*x + y*y))
iclamp Inverse-clamp x outside of the range r0 and r1. Where r0 < r1. If x is within the range it will snap to the closest bound. (eg: iclamp(r0,x,r1)
inrange In-range returns ‘true’ when x is within the range r0 and r1. Where r0 < r1. (eg: inrange(r0,x,r1)
log Natural logarithm of x. (eg: log(x))
log10 Base 10 logarithm of x. (eg: log10(x))
log1p Natural logarithm of 1 + x, where x is very small. (eg: log1p(x))
log2 Base 2 logarithm of x. (eg: log2(x))
logn Base N logarithm of x. where n is a positive integer. (eg: logn(x,8))
max Largest value of all the inputs. (eg: max(x,y,z,w,u,v))
min Smallest value of all the inputs. (eg: min(x,y,z,w,u))
mul Product of all the inputs. (eg: mul(x,y,z,w,u,v,t) == (x * y * z * w * u * v * t))
ncdf Normal cumulative distribution function. (eg: ncdf(x))
nequal Not-equal test between x and y using normalised epsilon
pow x to the power of y. (eg: pow(x,y) == x ^ y)
root Nth-Root of x. where n is a positive integer. (eg: root(x,3) == x^(1/3))
round Round x to the nearest integer. (eg: round(x))
roundn Round x to n decimal places (eg: roundn(x,3)) where n > 0 and is an integer. (eg: roundn(1.2345678,4) == 1.2346)
sgn Sign of x, -1 where x < 0, +1 where x > 0, else zero. (eg: sgn(x))
sqrt Square root of x, where x >= 0. (eg: sqrt(x))
sum Sum of all the inputs. (eg: sum(x,y,z,w,u,v,t) == (x + y + z + w + u + v + t))
swap Swap the values of the variables x and y and return the
<=> current value of y. (eg: swap(x,y) or x <=> y)
trunc Integer portion of x. (eg: trunc(x))
Trigonometry Functions
Function Definition
acos Arc cosine of x expressed in radians. Interval [-1,+1] (eg: acos(x))
acosh Inverse hyperbolic cosine of x expressed in radians. (eg: acosh(x))
asin Arc sine of x expressed in radians. Interval [-1,+1] (eg: asin(x))
asinh Inverse hyperbolic sine of x expressed in radians. (eg: asinh(x))
atan Arc tangent of x expressed in radians. Interval [-1,+1] (eg: atan(x))
atan2 Arc tangent of (x / y) expressed in radians. [-pi,+pi] eg: atan2(x,y)
atanh Inverse hyperbolic tangent of x expressed in radians. (eg: atanh(x))
cos Cosine of x. (eg: cos(x))
cosh Hyperbolic cosine of x. (eg: cosh(x))
cot Cotangent of x. (eg: cot(x))
csc Cosecant of x. (eg: csc(x))
sec Secant of x. (eg: sec(x))
sin Sine of x. (eg: sin(x))
sinc Sine cardinal of x. (eg: sinc(x))
sinh Hyperbolic sine of x. (eg: sinh(x))
tan Tangent of x. (eg: tan(x))
tanh Hyperbolic tangent of x. (eg: tanh(x))
deg2rad Convert x from degrees to radians. (eg: deg2rad(x))
deg2grad Convert x from degrees to gradians. (eg: deg2grad(x))
rad2deg Convert x from radians to degrees. (eg: rad2deg(x))
grad2deg Convert x from gradians to degrees. (eg: grad2deg(x))
String Processing
Function Definition
= , == All common equality/inequality operators are applicable
!=, <> to strings and are applied in a case sensitive manner.
<=, >= In the following example x, y and z are of type string.
< , > (eg: not((x <= ‘AbC’) and (‘1×2y3z’ <> y)) or (z == x)
in True only if x is a substring of y. (eg: x in y or ‘abc’ in ‘abcdefgh’)
like True only if the string x matches the pattern y. Available wildcard characters are ‘*’ and ‘?’ denoting zero or more and zero or one matches respectively. (eg: x like y or ‘abcdefgh’ like ‘a?d*h’)
ilike True only if the string x matches the pattern y in a case insensitive manner. Available wildcard characters are ‘*’ and ‘?’ denoting zero or more and zero or one matches respectively. (eg: x ilike y or ‘a1B2c3D4e5F6g7H’ ilike ‘a?d*h’)
[r0:r1] The closed interval [r0,r1] of the specified string. eg: Given a string x with a value of ‘abcdefgh’ then:
  • 1. x[1:4] ==‘bcde’
  • 2. x[ :5] ==x[:10 / 2] ==‘abcdef’
  • 3. x[2 + 1: ] ==x[3:] ==defgh’
  • 4. x[ : ] ==x[:] ==‘abcdefgh’
  • 5. x[4/2:3+2] ==x[2:5] ==‘cdef’
    Note: Both r0 and r1 are assumed to be integers, where r0 <= r1. They may also be the result of an expression, in the event they have fractional components truncation will be performed. (eg: 1.67 —> 1)
:= Assign the value of x to y. Where y is a mutable string or string range and x is either a string or a string range. eg:
  • 1. y := x
  • 2. y := ‘abc’
  • 3. y := x[:i + j]
  • 4. y := ‘0123456789’[2:7]
  • 5. y := ‘0123456789’[2i + 1:7]
  • 6. y := (x := ‘0123456789’[2:7])
  • 7. y[i:j] := x
  • 8. y[i:j] := (x + ‘abcdefg’[8 / 4:5])[m:n]
    Note: For options 7 and 8 the shorter of the two ranges will denote the number characters that are to be copied.
+ Concatenation of x and y. Where x and y are strings or string ranges. eg
  • 1. x + y
  • 2. x + ‘abc’
  • 3. x + y[:i + j]
  • 4. x[i:j] + y[2:3] + ‘0123456789’[2:7]
  • 5. ‘abc’ + x + y
  • 6. ‘abc’ + ‘1234567’
  • 7. (x + ‘a1B2c3D4’ + y)[i:2j]
+= Append to x the value of y. Where x is a mutable string and y is either a string or a string range. eg:
  • 1. x += y
  • 2. x += ‘abc’
  • 3. x += y[:i + j] + ‘abc’
  • 4. x += ‘0123456789’[2:7]
<=> Swap the values of x and y. Where x and y are mutable strings. (eg: x <=> y)
[] The string size operator returns the size of the string being actioned. eg:
  • 1. ‘abc’[] 3 * 2. var max_str_length := max(s0[],s1[],s2[],s3[]) * 3. ('abc' + 'xyz')[] 6
  • 4. ((‘abc’ + ‘xyz’)[1:4])[] == 4
Control Structures
Structure Definition
if If x is true then return y else return z. eg:
  • 1. if (x, y, z)
  • 2. if ((x + 1) > 2y, z + 1, w / v)
  • 3. if (x > y) z;
  • 4. if (x <= 2*y) { z + w };
if-else The if-else/else-if statement. Subject to the condition branch the statement will return either the value of the consequent or the alternative branch. eg:
  • 1. if (x > y) z; else w;
  • 2. if (x > y) z; else if (w != u) v;
  • 3. if (x < y) { z; w + 1; } else u;
  • 4. if ((x != y) and (z > w))
    y := sin(x) / u;
    z := w + 1;
    else if (x > (z + 1))
    w := abs (x – y) + z;
    u := (x + 1) > 2y ? 2u : 3u;
switch The first true case condition that is encountered will determine the result of the switch. If none of the case conditions hold true, the default action is assumed as the final return value. This is sometimes also known as a multi-way branch mechanism eg:
switch
case x > (y + z) : 2 * x / abs(y – z);
case x < 3 : sin(x + y);
default : 1 + x;
while The structure will repeatedly evaluate the internal statement(s) ‘while’ the condition is true. The final statement in the final iteration will be used as the return value of the loop. eg:
while ((x -= 1) > 0)
y := x + z;
w := u + y;
repeat/until The structure will repeatedly evaluate the internal statement(s) ‘until’ the condition is true. The final statement in the final iteration will be used as the return value of the loop.eg:
repeat
y := x + z;
w := u + y;
until ((x += 1) > 100)
for The structure will repeatedly evaluate the internal statement(s) while the condition is true. On each loop iteration, an ‘incrementing’ expression is evaluated. The conditional is mandatory whereas the initialiser and incrementing expressions are optional. eg:
for (var x := 0; (x < n) and (x != y); x += 1)
y := y + x / 2 – z;
w := u + y;
break, break[] Break terminates the execution of the nearest enclosed loop, allowing for the execution to continue on externa to the loop. The default break statement will set the return value of the loop to NaN, where as the return based form will set the value to that of the break expression. eg:
while ((i += 1) < 10)
if (i < 5)
j -= i + 2;
else if (i % 2 == 0)
break;
else
break[2i + 3];
continue Continue results in the remaining portion of the neares enclosing loop body to be skipped. eg:
for (var i := 0; i < 10; i += 1)
if (i < 5)
continue;
j -= i + 2;
return Return immediately from within the current expression. With the option of passing back a variable number of values (scalar, vector or string). eg:
  • 1. return [1];
  • 2. return [x, ‘abx’];
  • 3. return [x, x + y,‘abx’];
  • 4. return [];
  • 5. if (x < y)
    return [x, x – y, ‘result-set1’, 123.456];
    else
    return [y, x + y, ‘result-set2’];
?: Ternary conditional statement, similar to that of the above denoted if-statement. eg:
  • 1. x ? y : z
  • 2. x + 1 > 2y ? z + 1 : (w / v)
  • 3. min(x,y) > z ? (x < y + 1) ? x : y : (w * v)
~ Evaluate each sub-expression, then return as the result the value of the last sub-expression. This is sometimes known as multiple sequence point evaluation. eg:
~(i := x + 1, j := y / z, k := sin(w/u)) == (sin(w/u)))
~{i := x + 1; j := y / z; k := sin(w/u)} == (sin(w/u)))
[*] Evaluate any consequent for which its case statement is true. The return value will be either zero or the result of the last consequent to have been evaluated. eg:
case (x + 1) > (y – 2) : x := z / 2 + sin(y / pi);
case (x + 2) < abs(y + 3) : w / 4 + min(5y,9);
case (x + 3) == (y * 4) : y := abs(z / 6) + 7y;
[] The vector size operator returns the size of the vector being actioned. eg:
  • 1. v[]
  • 2. max_size := max(v0[],v1[],v2[],v3[])
