SP has several methods of Camera Calibration Tools depending on the need.
Calibration Tools
These tools can generate Lens Profiles and/or Alignment Profiles as well as position screens.
| Name | Notes | Generate Lens Profile | Generate Alignment Profile | Screen Alignment |
| Lens & Tracking Calibration | Combined calibration for camera intrinsic values and tracking calibration Screens needs to be at a fix location, the camera needs to change the location as well as rotation in the maximum possible range |
| Lens Calibration | Calibration of all camera intrinsic values without a tracking system Use a board or single screen/monitor for calibration Camera and screen do NOT need to have a fix location |
| Tracking Alignment | Calibration of the camera tracking system Capture a few images and calibrate the camera to the given screens |
| Alignment with Marker | Calibration of the camera tracking system Instead of a screen, known points can be used for this calibration |
| Simple Static Calibration | Combined calibration for camera intrinsic values and location alignment |
| Simple Static Calibration with Marker | Combined calibration for camera intrinsic values and location alignment |
* The tool “Lens Calibration” can position defined screens included curved led walls etc. to the correct location. But ONLY if they do NOT move during the calibration process.
Alternatively a single screen/monitor or board can be used for this calibration method and dosn´t needs to be static.
In this case the screen position will not work.
** A calibrated lens means a calibrated Lens Profile within SP or an incoming camera tracking protocol which includes all intrinsic values.
*** A tracking alignment based on a screen or multiple screens/curved walls needs to have the screens already well aligned
Tools
Reposition tools can modify an existing alignment profile, reposition a camera or position screens.
| Name | Notes | Need Calibrates Lens | Need Calibrated Tracking System | Need Screen |
| Screen Alignment | Align Screens from the given camera Needs at least a camera with Pan/Tilt encoder a full 6DoF tracking system will generate better calibration results with less images |
| Reposition from Screen | Can position a camera based on a screen Offsets a parent object or the camera location itself Can be used for tracking systems as well as non-tracked static cameras |
| Focusing on points | Can position a camera based on focusing to known points This tool modifying an existing alignment profile Just focus the camera to known points an capture the images |
Axis tools
This tool is within the Axis object.
| Name | Notes |
| Linear Axis | Calibrate a Camera on a linear axis This could be a straight rail, curved rail or similiar linear moving elements |
| Rotator Axis | Calibrate a Camera on a rotation axis This could be a turntable, pan/tilt of a jib or similar rotations |
| 2D Axis | Calibrate a Camera on a 2 axis system This could be a rail cam with an additional lift or similar systems |
