This is a native input for Blacktrax tracking data.
*This is only available for Tracking, Light Tracking, and Full license.
Blacktrax (RTTrPM) Setup
Input
| Name |
| Multicast Connection |
When on, data can be sent to multiple recipients. |
| Multicast Target IP |
| Interface |
Integer – These are whole numbers. |
| Local Port |
| Is Bound |
| Server |
Server name will be displayed here when connected. |
*Check the Calibration/Allignment Tool here.
Input Mapping
| Name |
- Centroid – The position of the object will be affected by the center of the blacktrax data.
- LED – This will handle the individual LED tracking data separately.
| ID |
The ID of the point can be added and the positional data from that point will be used. |
| Led |
This is the number of the LED point. |
| Position |
When on, the position of the object will be affected. |
| Rotation |
When on, the rotation of the object will be affected. |
| Velocity |
When on, the velocity of the object will be affected. |
| Acceleration |
When on, the acceleration of the object will be affected. |
Transform
| Name |
| Position |
- Global Position – The object will be affected by the global position of the data.
- Relative Position – The position of the object will be relative to the tracking data.
- Global Effected Position – The position of the object will be dependent on the global effected position.
| Rotation |
- Global Rotation – The object will be affected by the global rotational data.
- Relative Rotation – The rotation of the object will be relative to the tracking data.
- Global Effected Rotation – The rotation of the object will be dependent on the global effected rotation.
Status
| Name |
| Tracked State |
| Enable Recording |
When on, the tracking data can be recorded. |
Compatible input objects
