This is the Camera SDK software which provides 2D camera object data.
Optitrack Camera Setup
Status |
The status of the incoming data will be displayed here. |
Is Running |
When on, data is being recieved. |
Autostart |
When on, the Optitrack camera data will autostart. |
Start-Process |
This button starts the Optitrack process. |
Update Camera List |
This button updates the camera list. |
Advanced
Active Component |
When on, the Optitrack camera will be active. |
Cameras
Cameras can be added by pressing the + button next to the camera title.
Base Item
Available |
When on, the camera is available. |
Serial |
The serial of the camera can be added here. |
Id |
The Id number of the camera can be added here. |
The name of the camera can be written here. |
Model |
The camera model will be displayed here when the camera is connected. |
Framerate |
The frame rate of the camera added here. |
Exposure |
The exposure of the camera can be adjusted. |
Threshold |
The threshold of the camera can be adjusted. |
Intensity |
The intensity of the camera can be adjusted. |
Video Type |
- GrayScale Mode
- Object Mode
- MJPEG Mode
- Precision Mode
IR Filter |
When on, the infrared light will be filtered out. |
Gain |
This ranges from 1: Low(Short Range) to 8: Low(Long Range) |
MJPEG Quality |
The quality can be changed here. |
IR LED |
When on, the LED will emit infrared. |
Coloured LED Ring |
When on, the LED ring will be coloured. |
Colour LED Ring |
Colour of LED ring can be altered. Clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. |
Image Width |
The image width is determined by the camera type. |
Image Height |
The image height is determined by the camera type. |
Calibration
Offset Position |
Any positional offset to the data can be set. |
Offset Scale |
Any scale offset to the data can be set. |
Offset Rotation |
Any rotational offset to the data can be set. |
Align Tool |
Pressing this button will align the tracking data with the object. |
Clear Offset |
Pressing this button will reset all the offset coordinates. |
Optitack Camera Mapping
Use Active Marker |
When on, the data from the active marker will be used. |
Use Passive Marker |
When on, the data from passive markers will be used. |
Filter Camera |
When on, cameras will be filtered. |
Camera Serial |
the ID number or serial number of the camera can be added here. |
Position Type |
- Relative – The position of the data is relative to the object.
- Absolute – The position of the data is absolute to the world.
Status
Tracked State |
Enable Recording |
When on, the tracking data can be recorded. |
Mapping Polygon
Point |
This is the XY position of the initial point. |
Point 1 |
This is the XY position of the first point. |
Point 2 |
This is the XY position of the second point. |
Point 3 |
This is the XY position of the third point. |
Alpha |
This is the alpha level from 0 to 1. |
Border Colour |
The colour of the border can be altered. Clicking the colour box opens a colour picker with RGB (red, green, blue) and alpha control. |
Show Image |
When on, the image will be shown. |
Show Blobs |
When on, the blobs will be shown. |
Show Excludes |
Compatible Input Objects
