Search
The topic you requested could not be found.
StreamDeck
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » StreamDeck
See the discription here: StreamDeck Plugin
StreamDeck Plugin
StreamDeck Plugin
A StreamDeck can be used on the same computer where Stage Precision is running and also over network from other computers. Install the Stage Precision Stream Deck plugin by double click on the plugin file. After the installation is done open the StreamDeck…
The controller section contains controller devices, these devices can be added in and programmed to control different parameters within SP. The IO connections within this section are: GamePad Joystick StreamDeck 15 StreamDeck XL 32 3D Connexion …
