Media Input handles different types of live inputs.
These can be streams like NDI or multiple different SDI capture cards.
SDI capture cards can also be used as Genlock Provider.
The Media Inputs supports products from:
  • AJA Video Systems
  • Blackmagic Design
  • Bluefish444
  • DekTec
  • Deltacast
  • DirectShow
  • Magewell
  • Osprey
  • Stream Labs
Here is a list of all tested devices:
Please be aware that additional cards by the manufacturers above can also work inside SP, but have not been further tested.
Make sure to get in touch for compatibility consideration if you want to use a card that is not listed below.
Manufactor Device TC Support Nodes
AJA Video System
  • Corvid 88
  • Corvid 44
  • Corvid 24 R1
  • Corvid LHi
  • Corvid IP
  • Cona 5
  • Cona 4
  • Cona 1
Driver 16.1
Blackmagic Design
  • DeckLink SDI 4K
  • DeckLink 4K Extreme 12G
  • DeckLink Studio 2
  • DeckLink Studio 4K
  • DeckLink Quad 1
  • Intensity Pro 4K
  • DeckLink Mini Recorder
  • DeckLink 8K Pro
  • DeckLink Quad 2
  • Duo 2
Driver 12.1
Bluefish444
  • Epoch Neutron
  • Epoch 4K Neutron
  • Epoch Supernova CG
  • Epoch 4K Supernova S+
  • KRONOS K8
Driver V6.4.1.7 (OEM Driver, WIN SDK)
Deltacast
  • DELTA-3G-e 22
  • DELTA-3G-elp-key 11
  • DELTA-3G-elp-d 8c
Driver 6.15
Magewell
  • Pro Capture Quad SDI
Driver 1.3.0.4030
Osprey
  • M15
  • M25
  • 915
  • 925
  • 935
  • 945
  • 1215
  • 1225
  • 1245
  • 1285
  • 1227
  • 927
Stream Labs
  • MH4LM
  • MS4
  • MSP2
  • Alpha HD
Driver 3.3.698.33308
