This is a node-based wave generator which can affect movement or other parameters of objects.
Wave Generator Setup
Type
  • Sine – This is a simple waveform.
  • Cos – This is a simple waveform similar to sine, however, it occurs 1/4 of a cycle earlier.
  • Saw – The wave rises consistently before sharply decreasing.
  • Triangle – The wave rises and decreases at the same rate.
Frequence This is the speed at which the values affect the targets or how quickly the wave reaches peaks and troughs.
Range The output min and max can be set here.
Message This is the output wave parameters.
