This switch node is able to take in multiple values, as well as a switch value which controls which of the input values are outputted.
Type
  • Float – Individual X, Y or Z data.
  • Integer – These are whole numbers.
  • Point – This sends out XY data.
  • Vector – Combined XYZ data.
Switch This value determines which ‘In’ input value is output.
In 1 This is the first float input value.
In 2 This is the second float input value.
In 3 This is the third float input value.
In 4 This is the fourth float input value.
In 5 This is the fifth float input value.
In 6 This is the sixth float input value.
In 7 This is the seventh float input value.
In 8 This is the eighth float input value.
In 9 This is the ninth float input value.
In 10 This is the tenth float input value.
Out This is the selected output value.
