Search
IO Connections
Stage Precision » Stage Precision » Views / Elements » IO Connections
IO Connections are input and output protocols and/or devices which is how tracking, movement and trigger events are communicated in and out of Stage Precision. IO Connections can be added using the + button. 2D Tracking 3D Tracking Audio Camera…
IO functions
Stage Precision » Stage Precision » Scripting » General use of Scripting » IO functions
For some IO-Connections are special functions avaiable. OSC: OSC.send("address", variable); To send a OSC value from a script you need to define the address/path and a value what you whant to send. The type of the value is depending of the type of your variable.…
OSC IO Event filter
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » OSC » OSC IO Event filter
The OSC IO can directly filter OSC messages to trigger actions in Stage Precision. Create an “on message” event directly in the IO to add a message filter with a click on the (+): It´s now possible to use different conditions: 1th…
Synchronisation of IO Connection
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Synchronisation of IO Connection
All time critical IO Connections have advanced synchronization options. This options can be found in the tab “sync” within the added IO. In- and Outputs can be delayed per frame as well as within subframes. Inputs can be have different additional…
Gateway IO in Stage Precision
Gateway » Gateway IO in Stage Precision
Add a IO Connection “Gateway” in Stage Precision. You need to define the Gateway IP. This is the IP address of a computer in your network where Gateway is running. The Gateway Port needs to stay on 37777. If you want to use the WakeOnLan function you also…
Process Rate
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Process Rate
Prossesses can be found on the title bar, this contains the Main Process Rate of Stage Precision. Name Description Main Process Rate All calculations and all synced Outputs will be locked to this timing. Gui Refresh Rate…
Views / Elements
The layout of the user interface can be altered. The layout sections can be found under the View tab. Inspector Objects IO Connections Input Interpolation Viewport Timeline Timeline Recording Board & Nodes Monitor Mapping2D Pool Log Viewer Layer…
PTZ Cameras
Stage Precision » Stage Precision » Views / Elements » IO Connections » PTZ Cameras
These are native IO connections for controlling Pan, Tilt, Zoom cameras. The IO connections within this section are: Panasonic PTZ
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton
Skeleton IO connections are a selection of points which correspond to the joints of the body, this IO connection allows for incoming skeleton data. The IO connections within this section are: Kinect Perception Neuron Azure Kinect
0.8.134 / 0.8.135
2D Tracking
Stage Precision » Stage Precision » Views / Elements » IO Connections » 2D Tracking
The 2D tracking sections contains tracking IO connections that only work within a 2D space, usually XY data (horizontal and vertical) but no depth or Z data. The IO connections within this section are: Optitrack Camera Blobtracking Client Sick LMS Tuio …
Audio
Stage Precision » Stage Precision » Views / Elements » IO Connections » Audio
The IO connections within this section are: L-Acoustics L-ISA Sound Card
Services
Stage Precision » Stage Precision » Views / Elements » IO Connections » Services
The IO connections within this section are: Gateway
Utilities
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities
The IO connections within this section are: SPGateway
Synchronization
Stage Precision » Stage Precision » Views / Elements » IO Connections » Synchronization
These are a selection of input and output timecode connections. The IO connections within this section are: MTC IN MTC OUT LTC SMTPE Blackmagic Decklink
Image Provider
Stage Precision » Stage Precision » Views / Elements » IO Connections » Image Provider
The IO connections within this section are: Mjpeg Camera Module Web Camera
0.8.122
Media Server
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server
The media server section contains native connections to different types of media servers, depending on the media server will depend on how the IO connection can be used and how much it can control. The IO connections within this section are: Bright…
3D Tracking
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking
This 3D tracking section contains IO connections for 3D objects and 3D space tracking, including objects, skeletons and cameras. All of these tracking protocols have XYZ data. The IO connections within this section are: Antilatency Blacktrax…
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller
The controller section contains controller devices, these devices can be added in and programmed to control different parameters within SP. The IO connections within this section are: GamePad Joystick StreamDeck 15 StreamDeck XL 32 3D Connexion …
SMT
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » SMT
The SMT IO is a camera tracking protocol from the SportsMEDIA Technology Corporation. *This is only available for Virtual Production, and Full license. Setup the SMT IO Connection Add the SMT IO within the IO Connections. define the port and the local…
FactoryOptic – Syncro-Link
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » FactoryOptic – Syncro-Link
Syncro-Link from FactoryOptic is a lens readout system. This device sends Zoom, Focus and Iris as ranged values from 0-100% into a Camera object. *This is only available for Virtual Production, and Full license. Add the FactoryOptic connection The FactoryOptic IO…
LOLED Virtual / LONET
Yocto-Color-V2
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Yocto » Yocto-Color-V2
The Yocto-Color-V2 is a RGB LED driver. The Yocto-Color-V2 IO can be added with a click on the (+) within the IO Connections. Within the Inspector the Yocto-Color-V2 needs to know the connection mode (USB or Network) and add the device Serial. *With a click on…
Yocto-RangeFinder
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Yocto » Yocto-RangeFinder
The Yocto-RangeFinder is a USB distance sensor (range finder). The Yocto-RangeFinder IO can be added with a click on the (+) within the IO Connections. Within the Inspector the Yocto-RangeFinder needs to know the connection mode (USB or Network) and the device…
Switcher
Stage Precision » Stage Precision » Views / Elements » IO Connections » Switcher
Mixers and switches allow for multimedia freedom, these devices can be connected to cameras, content and other devices. IO Connections for various switches in this section include; Atem Switcher Panasonic AV-HS450 Panasonic AV-HS50 Panasonic AV-HS410 Smart…
ncam
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » ncam
ncam Reality is a hybrid camera tracking solution. www.ncam-tech.com *This is only available for Virtual Production, and Full license. The ncam IO can be added with a click on the (+) within the IO Connections. Within the Inspector the ncam server IP and the…
Slack Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Slack Bot
With the Slack Bot IO it´s possible to send notifications from SP directly into your Slack messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. Prepare Slack It´s necessary to prepare Slack before using this…
Peripheral
Stage Precision » Stage Precision » Views / Elements » IO Connections » Peripheral
The Peripheral sections contains auxiliary devices. The IO connections within this section are: BlackMagic Design HyperDeck “BlackMagic Design…
Camera Tracking
The IO connections within this section are: ARRI CAP FreeD UDP Star Tracker (Mo-Sys) Shotover G1 Stype (Stype HF) Technocrain UDP (SUPERTECHNO) Technocrain Serial (SUPERTECHNO) Cmotion
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Object Transform Protocol (OTP)
Object Transform Protocol is a 3D tracking protocol which supports position, rotation and scale. Stage Precision can send and receive object from the OTP protocol. Send OTP from Stage Precision (Producer) A sender within OTP called “Producer”. The OTP…
Artnet
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » Artnet
Adding Artnet The Artnet IO can be added with a click on the (+) within the IO Connections. within the Inspector a local interface needs to be defined the update rate for this protocol can be changed DMX monitor selecting the Artnet IO and click on the icon …
Yocto-GPS-V2
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Yocto » Yocto-GPS-V2
The Yocto-GPS-V2 device is a 72 channels receiver for GNSS signals emitted by GPS, GLONASS, GALILEO satellites. The Yocto-GPS-V2 IO can be added with a click on the (+) within the IO Connections. Within the Inspector the Yocto-GPS-V2 needs to know the connection…
Kinetic & Sensors
The Kinetic and Sensors section contains native automotive winches and equipment. The IO connections within this section are: MoveCat 4 x Encoder Input (1047) InterfaceKit 8/8/8 (1018) Voltage Input Phidget (V1000) Encoder Input Phidget (V1001) 8 x Voltage…
Events
Stage Precision » Stage Precision » Maps / Filter / Trigger » Events
Stage Precision has an internal event system to react on different events wich can be start from IO Connections, Interface elements and Objects. Within an event it´s possible to define an action. “Classical” Action-Events can be find in the following…
DCS
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » DCS
DCS is a Lens Data Translator. www.dcs.film Stage Precision can receive data from the LDT-V1. *This is only available for Virtual Production, and Full license. The DCS IO can be added with a click on the (+) within the IO Connections. Within the Inspector the…
Yocto-3D-V2
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Yocto » Yocto-3D-V2
The Yocto-3D-V2 is a USB 3-axis accelerometer, gyroscope and compass. The Yocto-3D-V2 IO can be added with a click on the (+) within the IO Connections. Within the Inspector the Yocto-3D-V2 needs to know the connection mode (USB or Network) and the device…
sACN
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » sACN
Adding sACN (Streaming ACN E1.31) The sACN IO can be added with a click on the (+) within the IO Connections. within the Inspector a local interface needs to be defined the update rate for this protocol can be changed *“raw” sACN universes can be…
Visca Server
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » Visca Server
The Visca Server IO creates an Visca over IP endpoint, so that SP can be controlled from a Visca based PTZ controller. *This is only available for Virtual Production, Light Tracking, Engineer, and Full license. Setup the Visca Server Connection Add the Visca Server…
OSC Setup
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » OSC » OSC Setup
OSC needs to be added in the IO-Connections. *Click on the (+) and type “OSC” or choose “protocol” in the menu and select OSC. By selecting the OSC-IO, the inspector shows the following options: *OSC is a bidirectional connection,…
Protocol
The protocol section contains a selection of open data package communications, these protocols are not device-specific and can be used a variety of ways. The IO connections in this section are: Artnet MIDI Modbus MQTT…
Maps Output
Stage Precision » Stage Precision » Maps / Filter / Trigger » Maps Output
IO Output Maps These are objects that are able to output data from the specific IO Connection. Protocol Protocol OSC MIDI Artnet SPNet Objects Tracker Camera Volume Surface Laser Fixture Pixel PTZ…
Genlock / Reference
Stage Precision » Stage Precision » Workflows » Project Framerate and Syncronisation » Genlock / Reference
Genlock Name Description Genlock Provider The specific genlock IO connection can be selected, using the target button. Interpolation Type Full interpolation None interpolation *The fps has four different color…
Vicon
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Vicon
Vicon is a motion capture solution. www.vicon.com/ *This is only available for Virtual Production, Tracking, Light Tracking, and Full license. The Vicon IO can be added with a click on the (+) within the IO Connections. Stage Precision can be connected to…
F4 (Mo-Sys)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » F4 (Mo-Sys)
Mo-Sys are camera tracking and robotic tracking systems, this IO connection is an input and output for the tracking data. *This is only available for Virtual Production, and Full license. !Map/Node Outputs can be used not only to send the F4 protocol to different…
TrackMen
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » TrackMen
TrackMen has multiple 3D real-timeTracking solutions among other things for camera tracking. *This is only available for Virtual Production, and Full license. Add a connection to TrackMen The TrackMen IO can be added with a click on the (+) within the IO…
0.8.130
Stage Precision » Changelog » 0.8.130
new IO Connections: FactoryOptics Spidercam Visca Watchout Trackman Telnet Phidget 0/16/16 New Nodes: Vector Axis Swapper Threshold Wait for trigger Script nodes can be now pushed/run with a trigger. Ping interface Trigger Count Trigger Switch New…
1.0.139 / 1.0.140
Stage Precision » Changelog » 1.0.139 / 1.0.140
New IO Connections: AJA Kumo Matrix Blackmagic Hyperdeck Blackmagic Multiview 4×4 Blackmagic Multiview 16×16 Blackmagic Ultimatte Blackmagic Videohub 12×12 Blackmagic Videohub 16×16 Blackmagic Videohub 20×20 Blackmagic Videohub…
Action
Stage Precision » Stage Precision » Views / Elements » Pool » Action
Actions can handle different trigger / functions which will be organized in the Pool. These Actions an be called from different “locations” like Buttons, Nodes, Timeline, ect… Everything what can handle events is able to run an Action. Add a Action…
0.8.128
Stage Precision » Changelog » 0.8.128
IO Connections: Qualisys Tracking Technocrane improvements to support 3-axes remote head LiveLink Support for UE 4.27.2 Camera Calibration / Lens Profile: new interpolation algorithm performance improvements for Distortion Viewer. Media Input /…
0.8.129
Stage Precision » Changelog » 0.8.129
new IO Connections: OBS WebSocket remote control vMix remote control Realsense T265 Stage One QPOS Websocket generic Improvements: better handling of recording keyframe interpolation color indicator for all disabled “container/options” better…
0.8.131
Stage Precision » Changelog » 0.8.131
New IO Connections: Object Transform Protocol Update Azure Kinect to SDK Version 1.4.1 (Firmware 1.6.110079014) Update Visca New Nodes: Composition Nodes / Nested Nodes Current Date Date to string Date Converter New Interface Object: Button Group New…
0.8.126
Stage Precision » Changelog » 0.8.126
Stage Precision 0.8.126 New IO Connections: Monogram Creative Console Skaarhoj Controller Deltacast input card New Features: General add relative mode to XY Stick Undo function for container reset Usebility support calculation also in fields with mm and…
DMX Patch
Stage Precision » Stage Precision » Workflows » Light Tracking » DMX Patch
Add DMX IO Add a sACN and/or ArtNet IO connection. Add DMX maps to the fixtures !If the DMX merging should happen on the same “universe”, make sure that you add seperated IO´s for In- and Output on seperated network interfaces. *See here the…
sACN Timeline Recording
Stage Precision » Stage Precision » Views / Elements » Timeline Recording » sACN Timeline Recording
sACN can be recordet within the Timline to replay the recordet stream. Only a sACN IO is needet (see here). Add a IO recording Layer Within the timeline with a secondary click, choose “IO Recording Layer” Define a recordable select the IO…
Modifying SteamVR
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » OpenVR (Vive & Oculus) » Modifying SteamVR
You need to install Steam and SteamVR on the same computer like Stage Precision is installed. For each Vive Tracker you need a Vive USB Dongle attached to your computer. After SteamVR is installed, go to the following…
Telegram Bot
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » Telegram Bot
With the Telegram Bot IO it´s possible to send notifications from SP directly into your Telegram messenger. Use this to monitoring your systems and send notifications in case of failures or status updates. It´s also possible to send from Telegram a specific messages…
Serial
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » Serial
Serial protocol is a protocol that transmits sequential data. This protocol is node-based, this worked with input and output messages within the board. Serial Setup Name Description Port This is the port that the data package will be sent…
Telnet
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » Telnet
TelNet is a protocol to control different devices. Add Telnet control within Stage Precision To add the Telnet IO-Connection, click on the (+) -> “Protocol” -> “Telnet”. Remote Host needs to be the IP adress of the Telnet device,…
Technocrane UDP (SUPERTECHNO)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Camera Tracking » Technocrane UDP (SUPERTECHNO)
The Technocrane is a camera crane system, this is the input for the crane tracking system. *This is only available for Virtual Production, and Full license. Input Name Description Local Port This is the port that will receive data from…
Antilatency
Stage Precision » Stage Precision » Views / Elements » IO Connections » 3D Tracking » Antilatency
This is a native input for Antilatency tracking data. Antilatency is an inside-out tracking system provider for VR/AR, Virtual Production, MoCap, Drones and Robotics. !AntilatencyService v4.0.0 needs to run and connected on the same computere where SP is…
In each Commander or in the Script editor you can have acces to different parameter and functions. You can read and write parameter to script your own needed logic. Here are more details to different topics: Debug with System Log Work with the…
Event Master
Stage Precision » Stage Precision » Views / Elements » IO Connections » Switcher » Event Master
Event Master Setup Name Description IP Address The IP address can be input. Interface This is the IP address of the local network interface which should be used for this connection. Connection When on, Event…
Monogram
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » Monogram
A Monogram controller can be used on the same computer where Stage Precision is running. !To see the necessary settings in the Monogram application click here Add a IO connection Monogram to start the communication between the controller and Stage Precision. *The…
UDP
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » UDP
User datagram protocol is a low-latency protocol, smaller data packets are sent and no response message is relayed back to the sender. This protocol is node-based, this worked with input and output messages within the board. UDP Setup Protocol Name…
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Remote control Material Parameter
Stage Precision can remote control parameter from Material Parameter Collections. They can be used within Unreal materials. Create a Material Parameter Collections Link the Material Parameter Collection within the Shield Settings Create parameter which…
Aumovis
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Aumovis
Aumovis is a automation system for moving LED screens around. The Aumovis system provides a single stream of position & rotation data per LED screen. *If your system has mutliple Aumovis platforms, it is necessary to create a single IO connection within SP for each…
Board & Nodes
Stage Precision » Stage Precision » Views / Elements » Board & Nodes
Interface Camera Links Objects Nodes Calculate Nodes Math Nodes Convert Nodes Smoothing Nodes Colour Nodes Utility Nodes Text Nodes Event Nodes Generator Nodes Composition Nodes Board Object Selection Layout The board acts as a control panel. Within…
SP Process Rate Genlock / Reference Timecode Synchronisation of IO Connection Input Synchronization Input Interpolation Output Synchronization Late Tick calculations / Low Latency
PJLink
Stage Precision » Stage Precision » Views / Elements » IO Connections » Utilities » PJLink
PJLink is a controlling protocol for projectors. A feedback of the projector will return within the IO Connection. (Status) The PJLink IO Connection provides trigger event maps. Different commands are avaiable wich could be maped to different trigger like a Button,…
AJA Kumo
Stage Precision » Stage Precision » Views / Elements » IO Connections » Switcher » AJA Kumo
AJA Kumo is a professional video router. A AJA Kumo can be remotely controlled from SP. Setup the AJA Kumo IO-Connection define the AJA Kumo IP address (Kumo IP). Trigger Maps Trigger Maps can be “called” among other things within interface objects…
Gateway
Gateway
Gateway is a small application which can be run on multiple machines in your network. It possible to send trigger commands with SP to one or several remote Gateway instances. Gateway Preferences Gateway IO in Stage Precision Commands from Stage Precision Gateway…
Skaarhoj
Stage Precision » Stage Precision » Views / Elements » IO Connections » Controller » Skaarhoj
A Skaarhoj controller can be used to control Stage Precision. !First you need to setup your Skaarhoj device. See here. Add a IO connection Skaarhoj to start the communication between the controller and Stage Precision. *The Skaarhoj IO can be found under controller.…
Midi
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » Midi
MIDI works typically with a midi device however it can be transmitted across Midi devices. Each midi data steam has 16 independent channels for messages and events. MIDI input and outputs can be added within the board as node-based parameters. MIDI Setup…
Interactive Trigger Area
Stage Precision » Stage Precision » Workflows » Interactive Trigger Area
Within SP, it is possible to define an area in 3D space for interactive purposes. Some of the things that SP can do once there is this defined area include: if an object has entered the area if an object has left the area when the defined area is empty if objects…
OSC
Open sound control or OSC is a protocol for sending data packages across a network. Data can be transmitted in various forms such as integer or float. OSC can be used directly as a map in or map output as well as nodes within the board. OSC Setup OSC Input…
Wachendorff Encoder (WDGA36)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Wachendorff Encoder (WDGA36)
Setup Name Description Port Choose the Serial Port Input. Baut Rate The Baut Rate of the Serial Port. Name Description Encoder Type Singleturn Encoder Multiturn Encoder Value…
MoveCat
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » MoveCat
MoveCat are a type of stage kinetic moving system. *This is only available for Kinetic Control, and Full license. MoveCat Setup Name Description Type V1 – This is the input for V1 movecat. V3 – This is the input for V3…
Erizos Studio
Stage Precision » Stage Precision » Views / Elements » IO Connections » Realtime Engine » Erizos Studio
Erizos Studio This integration connects to the Erizos Studio Profiles. Erizos Studio Name Description Log Response When On, response from the Pixotope system will be logged IO Data The response from the Erizos studio…
Azure Kinect
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Azure Kinect
To use the Azure Kinect IO connection, the kinect sensor(s) must first be added using the + button. !Azure Kinect SDK Version 1.4.1 (Firmware 1.6.110079014) is supported. Kinect Setup Coordinates Name Description Position The…
Lightware Matrix
Stage Precision » Stage Precision » Views / Elements » IO Connections » Switcher » Lightware Matrix
Lightware provides professional video matrix solution. A large variety of their matrices supports their LW2 protocol. Setup Lightware Matrix LW2 define the Lightware Matrix IP address (Remote Host) and port number (Remote port) and seletect the local network…
Mif 4 (Rosendahl)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Peripheral » Mif 4 (Rosendahl)
The mif4 Rosendahl is an interface to professional timecode. This IO connection allows SP to communicate with the Mif4 device and go into the different state. Once a Mif4 IO connection has been created, new SP actions can be created for this device. Trigger…
Vbo (Vertex Buffer Object)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Azure Kinect » Vbo (Vertex Buffer Object)
Coordinates Name Description Position The position of the kinect along the XYZ axis can be set. Scale The scale in meters can be set here. Rotation The rotation on the XYZ axis can be set. Vbo…
Perception Neuron
Stage Precision » Stage Precision » Views / Elements » IO Connections » Skeleton » Perception Neuron
Perception neuron is a motion capture suit with skeleton data. The IO connection takes in the perception neuron data. Perception Neuron Setup Name Description Server IP This is where the IP address of the server can be added. …
1.1.46
Stage Precision » Changelog » 1.1.46
New Integrations: Indiemark Lens Encoder Indiemark 2 Lens Encoder Glassmark II Lens Encoder Websocket New Nodes: Fading MTC In New Features: New Camera calibration tool: Simple Static Calibration to calibrate a fix lens and align the camera with a single…
d&b Soundscape
Stage Precision » Stage Precision » Views / Elements » IO Connections » Audio » d&b Soundscape
d&b Soundscape is an audio system processor to realize object-based mixing. www.dbsoundscape.com Stage Precision can drive the “audio-objects” among other things with realtime tracking data, controller inputs, timeline based programming and…
1.1.0
TCP
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » TCP
TCP is an error checking protocol, it is slower than UDP but will receive confirmation that the data package has been received. TCP Setup Protocol Name Description Protocol Type Raw – This is data that has not been…
VLC
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » VLC
To control VLC from Stage Precision it´s necessary to define some settings first. Prepare VLC for remote control 1. Open the preferences 2. Change the “show settings” in the lower right corner select “All” 3. Activate Web …
Blobtracking Client
Stage Precision » Stage Precision » Views / Elements » IO Connections » 2D Tracking » Blobtracking Client
Name Description Client IP The Ip address can be added manually or pressing the grey button will open a drop-down list. Client Port The client port can be added manually or by using the slider. Display Points …
Stage Precision » Stage Precision » Views / Elements » IO Connections » Kinetic & Sensors » Phidgets » InterfaceKit 8/8/8 (1018)
Phidget Setup Name Description Device Serial When the device is connected the serial number will be displayed here. Remote Name Description Host This is where the IP address of the host can be input.…
Vertex Commands
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Vertex Commands
++++h2. Input Name Description Local Port This is the port that will receive data from other devices. Is Bound This will be on when the IO connection is bound to a network. Multicast Connection When on, data…
MTC IN (Timecode)
Stage Precision » Stage Precision » Views / Elements » IO Connections » Synchronization » MTC IN (Timecode)
MTC is a MIDI timecode, which was initially made to keep MIDI equipment synced. Timecode in Stage Precision can be used to provide this for Outputs, to drive the Timline, to use it for Recordings and to access it inside the Node system. *The specific tasks will be…
Remote control Blueprint Variables
Shield for Unreal » Setting & Functions (v0.8) » Connect / Control Stage Precision with Shield » Remote control Blueprint Variables
Stage Precision can remote control nearly any puplic variable from Blueprints. Create variables within BluePrints and make them puplic !The BluePrint needs to be within the level to remote control the variables. Fetch the exposed parameter within the…
OSC Nodes
Stage Precision » Stage Precision » Views / Elements » IO Connections » Protocol » OSC » OSC Nodes
The OSC IO connection can be used within the node system. Simply drag and drop the IO-Connection onto the Board and choose the needed node. The OSC nodes supports the following connection types which can be defined within the Inspector:…
Stage Precision » Stage Precision » Workflows » Blob Tracking Workflows » Blob Tracking Management with Volume
Using the Volume object to manage the Point Data From the previous step either from the “Image Based Blob Tracking “:http://manual.stageprecision.com/stage.precision.beta/en/topic/image-based-blob-trackingor” Point…
Bright Sign
Stage Precision » Stage Precision » Views / Elements » IO Connections » Media Server » Bright Sign
Bright Sign Setup Name Description Playing When on the content is playing. Content The active contents name will be displayed here. Get Status By pressing this button the status of the active content will be…
