There are various types of input maps that can be taken into various different objects.
Input maps can also be from external IO connections. These maps translate the incoming data from the IO connection into data that the object can use, for example, positional and rotational coordinates.
Available input maps vary depending on the object type, therefore not all IO connections can be mapped into every object.
IO connections such as OSC are node-based and must be connected to the object parameters within the board.
All Map Input have the option to add delays to the individual components of the data packet.
Delay Position Delay the position data by x number of frames
Delay Rotation Delay the rotation data by x number of frames
Delay Custom Data Delay the custom data by x number of frames
Functions
Animator
Position The position where the animation will occur can be set using the XYZ axis values.
Rotation The rotation axis that the animation occurs on can be set using XYZ or HPB axis.
Animator This can be set to Linear or Circle, this is the direction of the animation.
Linear Animation
Type
  • Sine
  • Cos
  • Saw
  • Triangle
Frequency This is the frequency of the peaks and troughs of the type of wave, the higher the number the quicker the animation will move.
Position Factor This is the amount that the object will move on XYX axis, along the wave in meters.
Rotation Factor This is the amount of rotation the object will do while moving along the wave.
Circle Animation
Diameter The diameter of the circle on which the animation happens can be increased or decreased here.
Add Rotation If on, the object which is being affected by the animation will follow the rotation of the circle.
Rotation Offset An offset can be added to the rotation of the object.
Status
Tracked State
  • Undefined – When tracker does not have a map input.
  • Inactive – When the tracker has a follow object input map.
  • Active – When the tracker has a target object map input.
Enable Recording When on, recording of these movements is available.
Volume Points
Target Volume The target volume can be selected here, once selected individual points can be tracked.
Point Identifier
  • By Index – This selects points depending on the number of points within the volume.
  • By Id – This allows individual points to be specifically selected by their assigned number.
Point The number of the point to be tracked can be selected.
Status
Tracked State
Camera Specific SP Maps
UserData Simulator
User Parameter
Value 1
Frequency 1
User Parameter 1
Frequency 2
Frequency
Focus Target Object
Target Object An object can be assigned as a target by clicking on the target button.
Offset An offset in meters can be set here, this will be applied to the incoming data.
Status
Tracked State
IO Maps In
These are objects which are compatible with receiving data from specific IO connections.
2D Tracking
2D Tracking Tuio Optitrack Camera Sick LMS Blobtracking Client
Object
  • Tracker
  • Tracker
  • Volume
  • Volume
  • Volume
3D Tracking
3D Tracking Blacktrax (RTTrPM) Open VR Kinexon Optitrack (NatNet) Optitrack (Motive API) Pozyx Sewio PosiStageNet IN
Object
  • Tracker
  • Laser Fixture
  • Tracker
  • Skeleton
  • Camera
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Tracker
  • Skeleton
  • Camera
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 3
  • Light Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Tracker
  • Centroid
  • Tracker
  • Centroid
  • Tracker
  • Skeleton
  • Camera
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 2
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Tracker
  • Skeleton
  • Camera
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Tracker
  • Volume
  • Pixel
Camera Tracking
Camera Tracking ARRI CAP FreeD UDP Star Tracker (Mo-Sys) Stype (Stype HF) Technocrane Cmotion
Object
  • Camera
  • Camera
  • Tracker
  • Camera
  • Tracker
  • Camera
  • Camera
  • Camera
Kinectic & Sensors
Kinectic & Sensors MoveCat Phidget 1047-1 Phidget ENC1000
Object
  • Tracker
  • Moveable
  • Winch
  • Winch 3
  • Camera
  • Moveable
  • Moveable
  • Camera
Protocol
Protocol OSC Artnet SPNet
Object
  • Volume
  • Area
  • Tracker
  • Skeleton
  • Camera
  • Rigid Body
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 2
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Area
  • Tracker
  • Skeleton
  • Camera
  • Rigid Body
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
Skeleton Kinect Perception Neuron Azure Kinect
Objects
  • Tracker
  • Skeleton
  • Camera
  • Rigid Body
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 2
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Area
  • Skeleton
  • Tracker
  • Skeleton
  • Camera
  • Rigid Body
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 2
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
Controller GamePad Joystick 3D Connecion
Objects
  • Tracker
  • Skeleton
  • Camera
  • Rigid Body
  • Centroid
  • Volume
  • Moveable
  • Winch
  • Winch 2
  • Winch 3
  • Light Fixture
  • Laser Fixture
  • Pixel
  • Multipixel
  • PTZ Camera
  • Spotlight
  • Tracker
  • Tracker
  • Camera
Switcher
Switcher Type Artem Switcher (Blackmagic Design)
IO Connection
  • Skeleton
There are nodes within the board that also have mapping capabilities, below are the interface nodes and the compatible IO connections.
Interface Type Reference Button Slider Colour Field Controller
IO Connection
  • Artnet
  • SPNet
  • OpenVR
  • Sewio
  • Kinexon
  • GamePad
  • Kinect
  • Disto
  • Perception Neuron
  • OSC
  • MIDI
  • Artnet
  • SPNet
  • PSN Out
  • Vertex Commands
  • Artnet
  • SPNet
  • OpenVR
  • Sewio
  • Kinexon
  • GamePad
  • Kinect
  • Azure Kinect
  • Disto
  • Perception Neuron
  • OSC
  • Artnet
  • SPNet
  • OpenVR
  • Sewio
  • Kinexon
  • GamePad
  • Kinect
  • Azure Kinect
  • Disto
  • Perception Neuron
  • OSC
  • Artnet
  • SPNet
  • OpenVR
  • Sewio
  • Kinexon
  • GamePad
  • 3D Connexion
  • Kinect
  • Azure Kinect
  • Disto
  • Perception Neuron
