A trigger layer can be added by using the + button in the timeline.
This adds a layer where output triggers can be added easily along the timeline, these triggers will cause an event to happen at a certain time.
A trigger area can be added by double-clicking the in the timeline, the trigger time and event can be added in the inspector.
Trigger Block Setup
Time The exact time where the trigger will take place can be added here.
Locked When on, the trigger can not be moved in the timeline.
Maps Output The trigger event can be assigned. This can be an IO output map or an SP map.
