The topic you requested could not be found.
StreamDeck Plugin
StreamDeck Plugin
work in progress…
Stage Precision » IO Connections » Controller
The controller section contains controller devices, these devices can be added in and programmed to control different parameters within SP. The IO connections within this section are: GamePad Joystick StreamDeck 15 StreamDeck XL 32 3D Connexion …
Trim
Stage Precision » Board & Nodes » Text » Trim
This takes in the source text and trim the source text about the defined start and end indices. Trim Text Setup Name Description Source This is the input text. Start Index This is the start trim location of the source…
Gradient Effector
Stage Precision » Objects » Effector » Gradient Effector
