• Interface elements:
  • Button:
    • Button.press(); – press Button
    • Button.release(); – release Button
  • Slider:
    • Slider.cancel(); – cancel running fades
    • Slider.down(TimeInSeconds); – fade to min Value
    • Slider.fadeto(Value, TimeInSeconds); – fade to value
    • Slider.get(); – get slider value as float.
    • Slider.set(Value); – set slider value
    • Slider.toggle(TimeInSeconds); – toggle fade between min and max
    • Slider.up(TimeInSeconds); – fade to max Value
  • Cuelist:
    • Cuelist.get(); – get actual Cuenumber as Integer
    • Cuelist.next(); – trigger next Cue
    • Cuelist.previous(); – trigger previous Cue
    • Cuelist.set(CueNumber); – set Cuenumber as Integer
    • Cuelist.stop(); – trigger stop Cuelist
  • Label:
    • Label.get(); – get Label as String
    • Label.set("String"); – set String
  • Textfield:
    • Textfield.append("String"); – append String to Textfield
    • Textfield.appendLine("String"); – append String in new Line
    • Textfield.clear(); – clear Textfield
    • Textfield.get(); – get Text as String
    • Textfield.getFloat(); – get Text as Float
    • Textfield.getInt(); – get Text as Integer
    • Textfield.set("String"); – set Text as String
  • Objects from ObjectTree:
  • all Objects from the object tree has the following additional functions:
    • xx.getChildren(); – returns a Array with objects
    • xx.select(); – select object in inspector
  • Area:
    • Area.count(); – returns ammount of currently entered Objects as Integer
    • Area.getEnteredObjects(); – returns currently entered Objects as object
    • Area.isEmpty(); – returns a boolean, 1 if Area is empty 0 if is not
  • Camera:
    • Camera.activate(); – activate Camera in Viewport
  • Pool Items:
  • Action:
    • Action.run(); – run action
  • VarArray:
    • VarArray.append(Variable); – append Variable to the Array
    • VarArray.clear(); – remove all items from the Array
    • VarArray.get(Index); – get Variable needs index
    • VarArray.getArray(); – get the complete Array as array
    • VarArray.remove(Index); – remove object with the given index from the Array
    • VarArray.set(Variable, Index); – set Variable needs index
    • VarArray.size(); – get the size of the Array, return Integer
  • Script:
    • Script.run(); – run trigger script
    • Script.runValueChange(); – run ValueChange script
    • Script.runWithDelay(); – run trigger script with delay
  • Variable:
    • Variable.get(); – get Var value
    • Variable.set(Variable); – set Variable
