Phidget Setup
Device Serial The serial number of the device will be displayed when connected.
Encoder 0 The value of encoder 0 will be displayed here.
Autorange 0 When on, the ranges will be generated automatically.
Invert Range 0 When on, the min and max range values will be inverted.
Range 0 The minimum and maximum values can be added here.
Encoder 1 The value of encoder 1 will be displayed here.
Autorange 1 When on, the ranges will be generated automatically.
Invert Range 1 When on, the min and max range values will be inverted.
Range 1 The minimum and maximum values can be added here.
Encoder 2 The value of encoder 2 will be displayed here.
Autorange 2 When on, the ranges will be generated automatically.
Invert Range 2 When on, the min and max range values will be inverted.
Range 2 The minimum and maximum values can be added here.
Encoder 3 The value of encoder 3 will be displayed here.
Autorange 3 When on, the ranges will be generated automatically.
Invert Range 3 When on, the min and max range values will be inverted.
Range 3 The minimum and maximum values can be added here.
Digital Inputs
Input 0 When on, this input is connected.
Input 1 When on, this input is connected.
Input 2 When on, this input is connected.
Input 3 When on, this input is connected.
Compatible Input Objects
Node Mapping
Module Info The module information will be displayed here when connected.
Input 0 This will be on when the output is connected.
Input 1 This will be on when the output is connected.
Input 2 This will be on when the output is connected.
Input 3 This will be on when the output is connected.
Editable When on, the node is editable.
Locked When on, the node is locked into its position on the board.
