Panasonic AV-HS450 Setup
Protocol
  • Raw – This is data that has not been processed.
  • Lines – This sends data over a transmission line that will not overlap.
  • Data255 -
  • COBS – (Consistent Overhead Byte Stuffing) This is an encoding type that creates efficient data packages.
Port This is the port that the data package will be sent to.
Baud Rate This is the amount of information that can be communicated per second.
Crosspoints
Program Bus The button for this parameter can be assigned.
Preset Bus The button for this parameter can be assigned.
KeyS Bus The button for this parameter can be assigned.
KeyF Bus The button for this parameter can be assigned.
DSK1S Bus The button for this parameter can be assigned.
DSK1F Bus The button for this parameter can be assigned.
DSK2S Bus The button for this parameter can be assigned.
DSK2F Bus The button for this parameter can be assigned.
Pin P1 Bus The button for this parameter can be assigned.
Pin P2 Bus The button for this parameter can be assigned.
Aux 1 Bus The button for this parameter can be assigned.
Aux 2 Bus The button for this parameter can be assigned.
Aux 3 Bus The button for this parameter can be assigned.
Aux 4 Bus The button for this parameter can be assigned.
PushButton Actions
AutoTrans This button will trigger this parameter.
DSK1 This button will trigger this parameter.
Wipe This button will trigger this parameter.
Mix This button will trigger this parameter.
DSK2 This button will trigger this parameter.
PinP1 This button will trigger this parameter.
PinP2 This button will trigger this parameter.
Key This button will trigger this parameter.
PushButton Options
DSK 1 Take When on, this parameter will be controlled.
DSK 2 Take When on, this parameter will be controlled.
Wipe When on, this parameter will be controlled.
Mix When on, this parameter will be controlled.
RevWibe When on, this parameter will be controlled.
DSK1 PVW When on, this parameter will be controlled.
DSK2 PVW When on, this parameter will be controlled.
FTB Take When on, this parameter will be controlled.
Bkgd (N.Tms) When on, this parameter will be controlled.
Key (N.Tms) When on, this parameter will be controlled.
Key Take When on, this parameter will be controlled.
Key Take1 When on, this parameter will be controlled.
Dsk1 Take When on, this parameter will be controlled.
Dsk2 Take When on, this parameter will be controlled.
PinP1 Take When on, this parameter will be controlled.
PinP2 Take When on, this parameter will be controlled.
Key PVW When on, this parameter will be controlled.
Dsk1 Pvw1 When on, this parameter will be controlled.
Dsk2 Pvw1 When on, this parameter will be controlled.
PinP1/P2 Pvw When on, this parameter will be controlled.
Aux Trans When on, this parameter will be controlled.
Wipe Options
Wipe FX Wipe 1 to 85 can be chosen.
Fade Times
Cut after change? When on, there will be a cut after changes.
Bkgd selected? When on, the background is selected.
Key selected? When on, the keys are selected.
Fade Time The control fade time can be set here.
Transition Options
  • Bkgd, Key rate
  • Dsk1 Rate
  • Dsk2 Rate
  • PinP1 Rate
  • PinP2 Rate
  • Aux Rate
  • EFEDSLV Rate
Transition Mode
Transition on Key? When on, the transitions will be on the key.
Transition on Aux? When on, the transitions will be on Aux.
