Panasonic AV-HS410 Setup
Output
Remote Host This is where the target IP address of the host can be input.
Remote Port This is the port that the data package will be sent to.
Interface This is the IP address of the local network interface (NIC) which should be used for this connection.
Is Connected When on, the device is connected.
Reconnect This button can be pressed to reconnect the device.
Get Status The button can be pressed to get the status of the device.
Crosspoints
Bus A The output can be assigned here.
Bus B The output can be assigned here.
Program Bus The output can be assigned here.
Preview Bus The output can be assigned here.
KeyS Bus The output can be assigned here.
KeyF Bus The output can be assigned here.
Pin P1 Bus The output can be assigned here.
Pin P2 Bus The output can be assigned here.
Aux 1 Bus The AUX output can be assigned here.
Aux 2 Bus The AUX output can be assigned here.
Aux 3 Bus The AUX output can be assigned here.
Aux 4 Bus The AUX output can be assigned here.
Auto Transition Control
Wipe This button will trigger a wipe.
Mix This button will trigger the mix.
Key Trans When on, the key transition will be on.
PinP1 Trans When on, the transition will be on.
PinP2 Trans When on, the transition will be on.
FTB Trans When on, the transition will be on.
DSK Trans When on, the transition will be on.
Cut Transition Control
Background Pressing the button will trigger this transition.
Key Pressing the button will trigger this transition.
PinP1 Pressing the button will trigger this transition.
PinP2 Pressing the button will trigger this transition.
FTB Pressing the button will trigger this transition.
DSK Pressing the button will trigger this transition.
Auto Transition Times
Aux1 FadeTime When ticked the Aux1 transition will use the corresponding fade time.
PinP1 use FadeTime When ticked the PinP1 transition will use the corresponding fade time.
PinP2 use FaceTime When ticked the PinP2 transition will use the corresponding fade time.
Background FadeTime The fade time of the transition can be set here.
Key FadeTime The fade time of the transition can be set here.
PinP1 FadeTime The fade time of the transition can be set here.
PinP2 FadeTime The fade time of the transition can be set here.
FTB FadeTime The fade time of the transition can be set here.
Dsk FadeTime The fade time of the transition can be set here.
Aux Bus FadeTime The fade time of the transition can be set here.
PinP1 Bus FadeTime The fade time of the transition can be set here.
PinP2 Bus FadeTime The fade time of the transition can be set here.
Transition Pattern
Wipe Background FX The transition type can be selected from the drop-down list.
Wipe Key FX The transition key can be selected from the drop-down list.
Picture in Picture
Side-by-side When on, pictures wi
PiP1
Xpos The X axis position will be displayed here.
Ypos The Y axis position will be displayed here.
Size The size can be set here, by manually adding the number or toggling the slide bar.
Border Size
  • None
  • Small
  • Medium
  • Large
Border Luminance
  • 100%
  • 70%
  • 50%
  • 0%
  • No Change
PiP2
Border Size
  • None
  • Small
  • Medium
  • Large
Border Luminance
  • 100%
  • 70%
  • 50%
  • 0%
  • No Change
Tester
Send Trigger The trigger message can be manually added.
Send Pressing this button will output the trigger.
Answer The answer from the device will be displayed here.
