Joystick Ranger Setup
Lower X The lower or minimum X value range can be set.
Upper X The upper or maximum X value range can be set.
Center Point X The center point along the X range can be set.
Lower Y The lower or minimum Y value range can be set.
Upper Y The upper or maximum Y value range can be set.
Center Point Y The center point along the Y range can be set.
Center Threshold The center point can be increased by a percentage.
Clamp Values
In X The input X value will be displayed here.
In Y The input Y value will be displayed here.
Center When on the values will be centered.
Output Factor The range of the output values can be altered here. At 100 the full range of input values will be output.
Normalised X The normalised value converts the output to values between 0 and 1.
Normalised Y The normalised value converts the output to values between 0 and 1.
Out X The X value output will be displayed here.
Out Y The Y value output will be displayed here.
Out The XY values are output from the node here.
