Event Master Setup
IP Address The IP address can be input.
Interface This is the IP address of the local network interface (NIC) which should be used for this connection.
Connection When on, Event Master is connected.
Event Master Mapping
These commands are event-based and can be used within the interface Button and the Area object.
Command
Command
  • Cut
  • All Trans
  • Recall Next Preset
Preset
Call In
  • Preview
  • Program
Preset Number The preset number can be added here.
Name The name of the preset or program will be added here.
Cue
Action
  • Play
  • Pause
  • Stop
Cue Number The cue number can be added here.
Name The name of the cue can be added here.
Compatible Objects
