All SP parameters have the ability to be controlled by OSC. The OSC receiver port can be set within the Preferences settings, this is the port that OSC values can be sent to with the specific address for the individual parameter.
OSC Remote Setup
  1. The OSC Remote receiver port can be set in the Preferences section.
  1. OSC commands can be sent from an external source to this port. To affect the individual parameters the specific OSC address for the individual parameter needs to be set.
  1. The parameter OSC address can be found by right-clicking on the parameter and selecting ‘Copy OSC Address’.
  1. This copied address is the output destination for the OSC command.
  1. For the parameter to be affected relevant values need to be output. For example; Scale could be 0 to 1, however, Position must have equivalent XYZ values.
