A Fixture Profile is necessary to use a Tracking Light Fixture.
The Fixture Profile contains the DMX patch and physical parameter to receive/drive a light fixture.
Device
It´s possible to define here some informations about the fixture.
Parameter
This settings defines the parameter, specify the addresses and ranges as well as the physical parameter of a fixture.
The red line, left to the a parameter container as well as the addional desaturated icon, shows that this parameter will not be used within this Fixture Profile.
To activcate this, simply click on the desaturated icon.
Each parameter can have the following channel resolution options:
Mode DMX channels max. DMX range
8bit used 1 DMX channel 0-255
16bit used 2 DMX channels 0-65535
24bit used 3 DMX channels 0-16777215
32bit used 4 DMX channels 0-4294967295
The “Channel Address” defines always the “start address” of this specific parameter, independently if this is a 8bit or 32bit parameter.
Dimmer
set the resolution and DMX channel address for the Dimmer
Pan
set the resolution and DMX channel address for the Pan
Tilt
Zoom
Focus
Iris
Color
Choose the Color type:
  • RGB
  • CMY
  • RGBW
Templates
Templates can define different values for specific DMX channels.
Example Template – Highlight
