Recordings can be exported as FBX and CSV.
FBX export
With a click on the (I) within a recording layer opens a menu.
Click on “Export to FBX”.
CSV export
Click on “Export to CSV”.
Within the first row of the CSV is the header.
“Index” “Time” “Timecode” “Position X” “Position Y” “Position Z” “Rotation X” “Rotation Y” “Rotation Z” “Field of View” “Resolution X” “Resolution Y”
“Index”, “Time” and “Timecode” are always the first culomns, followed by changed parameters, followed by fixed parameters.
The second row is an initial entry to define the fixed parameter.
To identify the initial values we used as index a “-1”.
-1 90 1920 1080
This means, that “FoV” and “Resolution” has not any changed values within this recording.
From the third row for each frame will be a single row with all changed parameters.
-1 90 1920 1080
0 0 00:00:00:00 0.2240000069 1.0403000116 2.4026999474 -3.5999996662 -7.2199997902 -0
1 0.0099999998 00:00:00:00 0.2204000056 1.038599968 2.4028999805 -3.8800001144 -6.6700005531 -0
2 0.0500000008 00:00:00:01 0.2185000032 1.037700057 2.4030001163 -4.0300002098 -6.3800001144 -0
3 0.0799999982 00:00:00:02 0.2144999951 1.0355000496 2.4031000137 -4.3399996758 -5.759999752 -0
4 0.1099999994 00:00:00:03 0.2101999968 1.033100009 2.4031999111 -4.6799998283 -5.0999994278 -0
5 0.150000006 00:00:00:04 0.2079000026 1.0318000317 2.4031999111 -4.8600001335 -4.7499995232 -0
6 0.1800000072 00:00:00:05 0.2030999959 1.0291999578 2.4033000469 -5.2199993134 -4.0100002289 -0
7 0.2099999934 00:00:00:06 0.1979999989 1.0262999535 2.4033000469 -5.6199998856 -3.2200000286 -0
8 0.25 00:00:00:07 0.1952999979 1.0247000456 2.4031999111 -5.8299994469 -2.8199996948 -0
9 0.2800000012 00:00:00:08 0.1898999959 1.021600008 2.4031000137 -6.2399992943 -1.9999998808 -0
10 0.3100000024 00:00:00:09 0.1846999973 1.0184999704 2.4028999805 -6.6199989319 -1.2300001383 -0
11 0.349999994 00:00:00:10 0.1823000014 1.0168999434 2.4028999805 -6.8099989891 -0.869999826 -0
12 0.3799999952 00:00:00:11 0.1774999946 1.0139000416 2.4026999474 -7.1499996185 -0.1999999881 -0
13 0.4099999964 00:00:00:12 0.1729000062 1.010800004 2.4024999142 -7.4599995613 0.4199999273 -0
14 0.4499999881 00:00:00:13 0.170599997 1.0091999769 2.4024999142 -7.6099991798 0.719999969 -0
15 0.4799999893 00:00:00:14 0.1662999988 1.0061999559 2.402299881 -7.8800001144 1.2699998617 -0
16 0.5099999905 00:00:00:15 0.1623000056 1.0031000376 2.4021999836 -8.1199989319 1.7600001097 -0
17 0.5500000119 00:00:00:16 0.1604000032 1.0015000105 2.4021999836 -8.2400016785 1.9899998903 -0
18 0.5799999833 00:00:00:17 0.1565999985 0.9984999895 2.4021999836 -8.4400005341 2.4000000954 -0
19 0.6100000143 00:00:00:18 0.1532000005 0.9955000281 2.4021999836 -8.610001564 2.7699999809 -0
