• Float
    • value.get() will return the value.
    • value.set(123) will set the value to 123,00.
    • value.set(456.789) will set the value to 456,789.
  • Int
    • value.set(123) will set the value to 123.
  • Bool
    • checkbox.get() will return the state as 0 for false and 1 for true.
    • checkbox.set(0) will set the checkbox to false.
    • checkbox.set(1) will set the checkbox to true.
  • String
    • string.get() will return the string.
    • string.set("Test String 123") will set the string value to Test String 123.
  • Color [R, G, B, A]
    • color.get() will return an array with the size of 4.
    • color.get()[0 ] will return the first entry (R ) of the array [1 ] the second (G ) and so on…
    • color.set([1, 0, 0, 1]) will set the color to red.
    • color.set([0, 1, 0, 1]) will set the color to green.
    • color.set([0, 0, 1, 1]) will set the color to blue.
    • color.set([1, 1, 1, 1]) will set the color to white.
    • color.set([0.5, 0.5, 0.5, 1]) will set the color to 50% grey.
    • The values are ranged from 0,0 – 1,0.
  • Vector [X, Y, Z]
    • vector.get() will return an array with the size of 3.
    • vector.get()[0 ] will return the first entry (X) of the array [1 ] the second (Y) and so on…
    • vector.set([12.34, 43.21, 56.78]) will set the values X=12,34 Y=43,21 Z=56,78.
Point [X, Y]
  • point.get() will return an array with the size of 2.
  • point.get()[0 ] will return the first entry (X) of the array [1 ] the second (Y).
  • point.set([12.34, 43.21]) will set the values X=12,34 Y=43,21.
