Client IP The Ip address can be added manually or pressing the grey button will open a drop-down list.
Client Port The client port can be added manually or by using the slider.
Display Points When on, the points will be displayed.
Show Image
  • Depth
  • Blob
  • Coloured Blob
  • Mask
Image Update Rate
  • Setup (10fps)
  • Run (1fps)
  • None
Load Settings The settings will be loaded by pressing the button.
Write Settings
Camera The specific camera can be selected using the target button.
Input
Multicast Target IP This is where the IP address of the multicast can be entered.
Local Port This is the port that will receive data from other devices.
Interface This is the IP address of the local network interface (NIC) which should be used for this connection.
Is Bound This will be on when the IO connection is bound to a network.
Min Radius The minimum radius can be set here.
Near Threshold The near-threshold of the image can be set.
Far Threshold The far threshold of the image can be set.
Erode
Dilate
Blur The blur amount can be set here.
Blob
Max Radius The maximum radius can be set here.
Persistence
Max Distance
Exclude
Top This is the amount the image will be cropped from the top.
Bottom This is the amount the image will be cropped from the bottom.
Left This is the amount the image will be cropped from the left.
Right This is the amount the image will be cropped from the right.
Rectangle and Polygon
Rectangles and Polygons can be added by pressing the + button.
Rectangle
Position The XY position can be set here.
Size The size of the rectangle XY can be set here.
Polygon
Point 1 The XY position of the point can be set here.
Point 2 The XY position of the point can be set here.
Point 3 The XY position of the point can be set here.
Point 4 The XY position of the point can be set here.
