Timecode
Timecode in Stage Precision can be used to provide this for Outputs, to drive the Timline, to use it for Recordings and to access it inside the Node system.
*The specific tasks will be defined within the TimeManager, then you also can access this TC as Timecode node.
Timecode Setup
Device: |
Choose your DeckLink card/input. |
Connection: |
Choose the connection type. |
FrameRate: |
TC frame rate. |
Timecode Type: |
- vitcF1
- vitcF2
- VITC 1
- VITC 2
- LTC
- HFRTC
!Make sure, that the Timecode Type matched with the embeddet TC source.
!Make sure, that the FrameRate matched with the needed TC.
If the embeddet TC is the half of the incomming speed it´s possible to interpolate these up to the FrameRate settings.
To open a floating monitor window of the incoming TC, click on this icon:
Genlock/Reference
You can use an SDI Input to lock Stage Precision.
*To define this Decklink Input as Genlock reference open the TimeManager.
Genlock Setup
Device: |
Connection: |
Use incoming Format: |
auto signal format detection on/off. |
Mode: |
See/Set the actual signal format. |
!Make sure, that the Processes timings matched the rate of your incoming signal format.
!If your incoming signal is an Interlaced sinal make sure that the inerpolation Type in the TimeManager. is set to Full Interpolation.
*If your Processes should run at 100fps but your incoming signal format is 50fps make sure that the inerpolation Type in the TimeManager. is set to Full Interpolation.
!Do always have “Process Videoframe” deactivated if you will use TC or Genlock with this IO Connection.
